Fibre Router IP address please
- Re: Fibre Router IP address please
22-10-2012 6:11 PM
Hi peeps,
I'm moving to PlusNet Fibre from Sky BB later this month. My Sky router has a base address of 192.168.1.1 and some of my network devices have fixed IP addresses, e.g. 192.168.1.88 is my printer.
What is the base address of the PlusNet Fibre Router? If it is 192.168.0.1 then I need to prepare for the changeover. Or, is it very easy to reset the base address?
Geoff,
York.
York.
Message 1 of 7
(2,885 Views)
6 REPLIES 6
22-10-2012 9:12 PM
The PlusNet supplied TG582n router has a LAN side IP of 192.168.1.254, and the DHCP server is set up to issue IP addresses from 192.168.1.65 upwards. The easiest thing to do (i.e. "path of least resistance") with this if you want "static" IPs on your LAN is to connect up each device and let the router allocate an IP then in the router's GUI tick the box to "always use the same IP for this device". You probably won't get the same IPs you had before though.
Message 2 of 7
(1,107 Views)
22-10-2012 9:37 PM
Thanks for that! Now I know what I'll be dealing with I'll be able to set my devices to receive their IP address from the router in advance of the changeover. I'll maybe revert back to (some) fixed in the future!
Geoff,
York.
York.
Message 3 of 7
(1,107 Views)
22-10-2012 10:53 PM
If none of your fixed IPs have their last octet above 100 (say) you could alter the DHCP range to start at 192.168.1.100 then no need to change existing fixed IPs. However it would be necessary to make the DHCP range change again if a factory reset is performed.
Another option is to give devices new fixed IPs which are below 192.168.1.64. That would be proof against a factory reset (or firmware upgrade).
David
Message 4 of 7
(1,107 Views)
23-10-2012 12:03 PM
Quote from: spraxyt
Good thinking! I can do that right now without complicating existing or new routers!
Geoff,
York.
York.
Message 5 of 7
(1,107 Views)
23-10-2012 12:48 PM
Okayyy... ... but on those devices that you manually configure the TCP/IP settings you'll likely still need to change things like the default gateway and maybe DNS and WINS servers to suit the new router once it's running. Depends on what you connecting.
Message 6 of 7
(1,107 Views)
23-10-2012 1:41 PM
I'm connecting an IP camera and my printer on fixed IP addresses. Gateway and DNS IP's will be set up after new router installed. However, I can now address both devices thru' either router!
Many thanks guys for your help!
Geoff,
York.
York.
Message 7 of 7
(1,107 Views)
