Down time.
- Re: Down time.
Down time.
16-12-2012 9:17 PM
Anybody else had problems yesterday, it looks like my connection was down for about 5 and a half hours. The red light on my router was showing when I got in. I clicked connect and it was ok after that.
12/15/2012 19:55:54 If(ATM1) PPP fail : Peer terminate
12/15/2012 19:55:52 ATM1 start PPP
12/15/2012 19:55:52 If(ATM1) PPP fail : Peer terminate
12/15/2012 19:55:50 ATM1 start PPP
12/15/2012 19:55:28 login success
12/15/2012 19:54:26 sending ACK to
12/15/2012 19:19:34 NTP Date/Time updated.
12/15/2012 14:30:28 If(ATM1) PPP fail : Peer terminate
12/15/2012 14:30:27 ATM1 get IP:
12/15/2012 14:30:26 ATM1 start PPP
12/15/2012 14:30:25 If(ATM1) PPP fail : Peer terminate
12/15/2012 14:30:23 ATM1 start PPP
Message 1 of 5
(1,019 Views)
4 REPLIES 4
Re: Down time.
16-12-2012 9:29 PM
does look like an issue at PN rather than with your line, but there was no large outage or service status.
Message 2 of 5
(408 Views)
Re: Down time.
16-12-2012 9:37 PM
I did get DC more than once in a short amount of time too. slow speeds at times too.
Message 3 of 5
(408 Views)
Re: Down time.
17-12-2012 11:03 AM
Had a look at your connection and it doesn't show any disconnection for that period of time.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13557420563235.png"/>
May have been a blip, I wouldn't be to worried at the moment unless it was to happen again.
Message 4 of 5
(408 Views)
Re: Down time.
17-12-2012 9:27 PM
Thanks for the graph Chris, it looks like I came home and looked at the router just as it had a peer teminate and hadn't been down for a few hours.
Last week I saw someone laying cables along my road outside my house. I asked him if it was fibre and he said yes. You can imagine my mood until he said it was virgin and it was only going to be used for schools and businesses.
Message 5 of 5
(408 Views)
