New install - help needed
dsw
Well, it seems I am now going to be out of pocket. Even if it is by a small amount. Is it possible to cancel a new connection?
I'm moving in to a property and it's not guaranteed that I'll be there past 6 months so I need no contract.
Based on old pricing:
6.49 x 6 = £39.94 + £25.00 activation fee = £63.94
New pricing:
£8.49 * 6 = £50.94
Can you advise?
Fixes: 60
Re: New install - help needed
Moved to it's own thread to avoid getting lost
dsw
Even over a longer period it still works out cheaper on the new package.
dfunked
Surely you can still order the old package today and tomorrow?...
Fixes: 127
If you've already signed up on the existing package you won't be compelled to move so you shouldn't be out of pocket at all.
Will Moderate For Thanks
Fixes: 60
To go back to the original question this is the actual position
http://www.plus.net/info2/legal/index.html
When the service starts
    The service will begin on the day we send you any equipment required to use the service, or on the day we activate the service whichever is later.
Cancellation
    You may cancel your agreement for the service before the service start date set out in the service terms. If you do so we will not charge you for the service.
So basically if it hasn't happened you should be able to cancel without charge and then order again after Wednesday
Alternatively - if the install/activation date is after Wednesday leave it until then and then phone up as you just may be able to change to the new product without losing your slot in the queue
Fixes: 46
Have you checked the activation and no-contract charges for the new product? I didn't think they were zero.
David
