Dns seems high
Fixes: 162
Re: Dns seems high
@Kelly,
have the DNS been reconfigured so as not to respond to ping requests?
#Microsoft Windows [Version 6.1.7601]
#04/06/2014-16:37:13.35
C:\Users\Kevin>tracert plus.net
Tracing route to plus.net [212.159.8.2]
over a maximum of 30 hops:
  1  344 ms    1 ms    1 ms  dsldevice.lan [192.168.1.254]
  2    50 ms  559 ms    35 ms  lo0-central10.ptw-ag03.plus.net [195.166.128.197]
  3    36 ms    35 ms    35 ms  link-a-central10.ptw-gw01.plus.net [212.159.2.152]
  4  384 ms    35 ms    35 ms  xe-4-3-0.ptw-cr01.plus.net [212.159.0.244]
  5    35 ms    35 ms    37 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  6  423 ms    45 ms    43 ms  gi5-1.peh-cr02.plus.net [84.93.232.61]
  7    45 ms    47 ms    44 ms  po5.peh-cr01.plus.net [84.93.232.16]
  8  239 ms    47 ms    44 ms  vlan2658.peh-elb02.plus.net [84.93.232.53]
  9    46 ms    46 ms    47 ms  portal.plus.net [212.159.8.2]
Trace complete.
#04/06/2014-16:37:37.39
C:\Users\Kevin>ping 212.159.6.9
Pinging 212.159.6.9 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 212.159.6.9:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
#04/06/2014-16:38:05.39
C:\Users\Kevin>ping 212.159.6.10
Pinging 212.159.6.10 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 212.159.6.10:
Note neither DNS address responds to ping requests, though the DNS is clearly working at the time of the test.
Cheers,
Kevin
Kelly
Fixes: 9
Re: Dns seems high
It's locked down to just DNS/NTP traffic at the minute.
Kelly Dorset
Ex-Broadband Service Manager
30FTTC06
Fixes: 4
Re: Dns seems high
Pretty tight for me at the moment, I can only see one side though, I'm guessing you have locked access to one side at the moment while testing  Smiley
[tt]IP          Avg (ms)  Min Max  TO NX
212.159.6.9  24.75 21.7 40.1 0  0[/tt]
npr
Fixes: 9
Re: Dns seems high
Quote from: Kelly
If all is well, we'll do the other side asap.
Can't be soon enough, the difference between the two sides is huge.
Gateway pcl-ag05
212.159. 13. 50 |  Min  |  Avg  |  Max  |Std.Dev|Reliab%|
  - Cached Name  | 0.026 | 0.029 | 0.047 | 0.004 | 93.5 |
  - Uncached Name | 0.028 | 0.079 | 0.322 | 0.081 | 90.7 |
  - DotCom Lookup | 0.035 | 0.079 | 0.141 | 0.039 |  89.7 |
  ---<O-OO---->---+-------+-------+-------+-------+-------+
                    cdns02.plus.net
                PLUSNET PlusNet PLC,GB
212.159. 13. 49 |  Min  |  Avg  |  Max  |Std.Dev|Reliab%|
  - Cached Name  | 0.026 | 0.030 | 0.049 | 0.006 |  86.4 |
  - Uncached Name | 0.029 | 0.115 | 0.369 | 0.109 |  92.1 |
  - DotCom Lookup | 0.035 | 0.080 | 0.141 | 0.042 |  85.7 |
                    cdns01.plus.net
212.159.  6. 10 |  Min  |  Avg  |  Max  |Std.Dev|Reliab%|
  - Cached Name  | 0.026 | 0.032 | 0.150 | 0.019 | 95.5 |
  - Uncached Name | 0.029 | 0.085 | 0.284 | 0.079 |  95.2 |
  - DotCom Lookup | 0.034 | 0.084 | 0.141 | 0.042 |  97.5 |
                    cdns02.plus.net
212.159.  6.  9 |  Min  |  Avg  |  Max  |Std.Dev|Reliab%|
  - Cached Name  | 0.026 | 0.032 | 0.154 | 0.020 |  95.5 |
  - Uncached Name | 0.030 | 0.093 | 0.330 | 0.093 | 90.5 |
  - DotCom Lookup | 0.034 | 0.091 | 0.142 | 0.041 |  92.1 |
                    cdns01.plus.net
Gateway  ptw-ag01
  - Cached Name  | 0.022 | 0.024 | 0.026 | 0.001 | 100.0 |
  - Uncached Name | 0.023 | 0.077 | 0.317 | 0.082 | 100.0 |
  - DotCom Lookup | 0.029 | 0.083 | 0.140 | 0.043 | 100.0 |
                    cdns02.plus.net
  - Uncached Name | 0.023 | 0.083 | 0.318 | 0.086 | 100.0 |
  - DotCom Lookup | 0.030 | 0.088 | 0.138 | 0.040 | 100.0 |
                    cdns01.plus.net
  - Uncached Name | 0.023 | 0.094 | 0.324 | 0.087 | 100.0 |
  - DotCom Lookup | 0.030 | 0.080 | 0.136 | 0.044 | 100.0 |
                    cdns02.plus.net
  - Cached Name  | 0.023 | 0.024 | 0.026 | 0.001 | 100.0 |
  - Uncached Name | 0.023 | 0.082 | 0.313 | 0.082 | 100.0 |
  - DotCom Lookup | 0.030 | 0.077 | 0.137 | 0.042 | 100.0 |
                    cdns01.plus.net
30FTTC06
Fixes: 4
Re: Dns seems high
I can't fault it at the moment.
ptn-ag02
Kelly
Fixes: 9
Re: Dns seems high
Quote from: npr
Quote from: Kelly
Done!
Hopefully performance should be good tonight.  *crosses fingers*
Kelly Dorset
npr
Fixes: 9
Re: Dns seems high
Thanks for the update Kelly.
So far it's the best benchmark results I've ever had from PN name servers.
30FTTC06
Fixes: 4
Re: Dns seems high
Plusnet comes third in the list of the overall server tests, and first in the fastest response test.
Based on 1000 tests to each server twice just to make sure! So far so good.
Kelly
Fixes: 9
Re: Dns seems high
Stats from our side are looking good.... roll on the big test on Sunday night.
Kelly Dorset
30FTTC06
Fixes: 4
Re: Dns seems high
Well, it's looking good from where i'm standing... Big pat on the back from me.
Kelly
Fixes: 9
Re: Dns seems high
\o/
We've just closed off the service status as it looked pretty good over the weekend.
As usual, yell if you see any other problems.
Kelly Dorset
bobpullen
Fixes: 316
Re: Dns seems high
I've been on leave for the last few weeks but I must say, It's really satisfying to see such a positive improvement following the weekend's work.
Kudos to Kelly, Engineering/Operations, Digicare and everyone who's participated in this thread to help troubleshoot the issue Smiley
Before:
After:
Kelly
Fixes: 9
Re: Dns seems high
Took us to long to sort to be honest, but once we'd worked out what needed sorted the Ops Team sorted it quickly.  Thank you for keeping on our backs forum guys!
Kelly Dorset
