Disconnections.
- Disconnections.
Re: Disconnections.
01-06-2010 12:06 PM
Quote from: pierre_pierre Dont think you have every said what operating system you are on.
one laptop has XP, the other one vista and up to now no disconnection in any of them (2hours.. WOW! I managed to write a whole paragraph of my thesis including references!). Don't think it's operating system.
Quote from: pierre_pierre Have you got your log on to the router set to stay on all the time?
I believe so, as far is the default setting... also I've changed 3 routers and all do the same thing!
JELV: please stop looking at the finger when i point at the moon!! I'm using the VPN conection to keep a track, it's a tool, a probe... considering that the log seems not to show anything... how can I see if both laptops get disconnected simultaneously otherwise?
Re: Disconnections.
01-06-2010 12:36 PM
Re: Disconnections.
01-06-2010 1:10 PM
3 hours of connection in a row now... my neighbours must be at work! I start suspecting there is an interference with someone else...
If this is the case, who's responsible for cabling in the buiding? (this is a house converted to 4 flats) I've called the management company and they said that it's responsability of the provider to provide a reliable service...
Re: Disconnections.
01-06-2010 1:29 PM
Have you checked the status of your exchange? http://usertools.plus.net/exchanges/
Can you try doing something which loads the internet connection such as downloading something to see if that causes the VPN to drop (e.g. download a program from BBC iPlayer).
I don't think it would be the cabling in the building - that would be likely to cause disconnections, but if everybody else is at work the level of traffic going through your exchange may be lower.
Edit: If it is an exchange related problem going on to Max Premium which as well as giving you faster upload speeds gives you a higher priority on the BT network. When I was experiencing VPN problems with VPN software that didn't handle timeouts very well I found that moving to Max Premium made a noticeable improvement.
Re: Disconnections.
01-06-2010 1:58 PM
County: London - Greater
Enabled: 11 Oct 1999
Market: 3
VP capacity at this exchange is currently showing as Green.
Click here for further details
BT have advised that this exchange is enabled for WBC on 21CN
You can view recent Service Outages for this exchange here
BT has published DSL Max upgrade information for this exchange
Nope... no exchange problems. All lights are green (first 2) or grey (second two). when clicking on the second two does give no service outage and the exchange has been upgraded in 2006!
Quote from: jelv I don't think it would be the cabling in the building - that would be likely to cause disconnections, but if everybody else is at work the level of traffic going through your exchange may be lower.
Sorry, didn't get that.. you say that messed cabling WOULD be likely to cause disconnections? because that is the case...
Re: Disconnections.
01-06-2010 2:11 PM
Re: Disconnections.
01-06-2010 2:22 PM
My modem report back 2 connections for broadband
1. DSL connection (which is the sync with the exchange and this what gets disconnected when the line is noisy)
2. Internet Connection (This is the PPPoA session which PN control and is dropped for profile and gateway changes)
Both of these have timers and currently mine are at 2 days 16 hours which was the last time I lost sync with the exchange. Your modem display similar information and this is what you need to post to back up the disconnection you believe you are suffering from.
Re: Disconnections.
01-06-2010 2:35 PM
If you could open a cmd window and run the following two commands and copy paste the results back we would be able to tell if that is the case:
route print
tracert ntp.plus.net
The output should look something like this:
C:\Documents and Settings\John>route print
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 ff 68 7d 1a 8a ...... Juniper Network Connect Virtual Adapter
0x3 ...00 0f 1f 9b 02 53 ...... Intel(R) PRO/1000 MT Network Connection - SecuRemote Miniport
0x4 ...54 c1 07 0d 75 07 ...... Check Point Virtual Network Adapter For SecureClient - SecuRemote Miniport
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.104 20
83.244.140.24 255.255.255.255 192.168.0.1 192.168.0.104 1
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
169.254.0.0 255.255.0.0 192.168.0.104 192.168.0.104 20
172.16.0.132 255.255.255.255 127.0.0.1 127.0.0.1 10
172.16.255.255 255.255.255.255 172.16.0.132 172.16.0.132 10
192.168.0.0 255.255.255.0 172.16.0.132 172.16.0.132 1
192.168.0.104 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.0.255 255.255.255.255 192.168.0.104 192.168.0.104 20
192.168.100.0 255.255.255.0 172.16.0.132 172.16.0.132 1
224.0.0.0 240.0.0.0 192.168.0.104 192.168.0.104 20
255.255.255.255 255.255.255.255 172.16.0.132 4 1
255.255.255.255 255.255.255.255 172.16.0.132 172.16.0.132 1
255.255.255.255 255.255.255.255 192.168.0.104 192.168.0.104 1
Default Gateway: 192.168.0.1
Persistent Routes:
None
C:\Documents and Settings\John>tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.6.9]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms dg834 [192.168.0.1]
2 18 ms 14 ms 11 ms lo0-homesurf.ptn-ag02.plus.net [195.166.128.54]
3 11 ms 10 ms 10 ms gi2-7-705.ptn-gw01.plus.net [84.92.3.97]
4 11 ms 11 ms 11 ms vl55.ptn-lb01.plus.net [212.159.2.124]
5 13 ms 11 ms 11 ms cdns01.plus.net [212.159.6.9]
Trace complete.
Re: Disconnections.
01-06-2010 4:47 PM
sorry.. some stuff is in italian, but it should be clear anyway...
C:\WINDOWS\system32>route print
Elenco interfacce
0x2 ...00 12 f0 02 32 5a ...... Intel(R) PRO/Wireless 2200BG Network Connection
- Miniport dell'UtilitÓ di pianificazione pacchetti
0x3 ...00 0f b0 83 63 b5 ...... Marvell Yukon 88E8036 PCI-E Fast Ethernet Contro
ller - Miniport dell'UtilitÓ di pianificazione pacchetti
0x20005 ...00 53 45 00 00 00 ...... WAN (PPP/SLIP) Interface
Route attive:
Indirizzo rete Mask Gateway Interfac. Metric
0.0.0.0 0.0.0.0 152.78.36.8 152.78.36.8 1
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.3 21
83.9.173.219 255.255.255.255 192.168.0.1 192.168.0.3 20
152.78.36.8 255.255.255.255 127.0.0.1 127.0.0.1 50
152.78.128.159 255.255.255.255 192.168.0.1 192.168.0.3 20
152.78.255.255 255.255.255.255 152.78.36.8 152.78.36.8 50
192.168.0.0 255.255.255.0 192.168.0.3 192.168.0.3 20
192.168.0.3 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.0.255 255.255.255.255 192.168.0.3 192.168.0.3 20
224.0.0.0 240.0.0.0 192.168.0.3 192.168.0.3 20
224.0.0.0 240.0.0.0 152.78.36.8 152.78.36.8 1
255.255.255.255 255.255.255.255 152.78.36.8 152.78.36.8 1
255.255.255.255 255.255.255.255 152.78.36.8 2 1
255.255.255.255 255.255.255.255 192.168.0.3 192.168.0.3 1
Gateway predefinito: 152.78.36.8
Route permanenti:
Nessuno
C:\WINDOWS\system32>tracert ntp.plus.net
Rilevazione instradamento verso ntp.plus.net [212.159.6.10]
su un massimo di 30 punti di passaggio:
1 32 ms 34 ms 32 ms ip-036-000.vpn.soton.ac.uk [152.78.36.0]
2 33 ms 34 ms 37 ms b54rv2-v31.net.soton.ac.uk [152.78.128.17]
3 71 ms 81 ms 79 ms b54aagesw2-ba.net.soton.ac.uk [152.78.108.130]
4 37 ms 36 ms 35 ms b54gagesw1-aa2.net.soton.ac.uk [152.78.108.150]
5 37 ms 35 ms 38 ms b54gafwc1-int.net.soton.ac.uk [152.78.109.4]
6 38 ms 78 ms 82 ms b54gagesw2-hafw.net.soton.ac.uk [152.78.0.30]
7 105 ms 69 ms 82 ms 212.219.151.113
8 34 ms 37 ms 35 ms 195.194.38.33
9 39 ms 42 ms 38 ms lond-sbr1.ja.net [146.97.40.17]
10 38 ms 38 ms 38 ms so-6-0-0.lond-sbr4.ja.net [146.97.33.154]
11 41 ms 46 ms 37 ms ae0.lond-gw-ixp4.ja.net [146.97.35.182]
12 36 ms 36 ms 36 ms linx-gw1.plus.net [195.66.224.164]
13 53 ms 79 ms 81 ms te3-2.ptn-gw02.plus.net [212.159.1.105]
14 38 ms 39 ms 37 ms vl55.ptn-lb01.plus.net [212.159.2.124]
15 36 ms 36 ms 35 ms cdns02.plus.net [212.159.6.10]
Rilevazione completata.
Anything interesting?
Re: Disconnections.
01-06-2010 4:49 PM
Re: Disconnections.
01-06-2010 5:10 PM
Quote from: Laura1975 Anything interesting?
Oh yes!
I was right - when you have the VPN connected ALL traffic not destined for you local network is going via the university. That is particularly obvious if you compare your trace to the Plusnet time server to mine; yours you can see goes via the university, then out on to the Janet network before it reaches Plusnet.
So we are back where we began and your problem is VPN dropouts, not dropouts of the connection to Plusnet.
Did you manage to test whether generating a lot of traffic causes dropouts?
Re: Disconnections.
01-06-2010 5:32 PM
With VPN connected could you run the following command please:
ping -n 50 152.78.0.30
and then repeat the same command with the VPN disconnected.
Re: Disconnections.
01-06-2010 6:41 PM
How much of the time do you actually need to be connected to the university VPN? I bet if you only connect as and when needed and disconnect when done you'd find general browsing etc. a lot more usable.
Re: Disconnections.
01-06-2010 7:29 PM
Re: Disconnections.
01-06-2010 7:41 PM
Quote from: jelv I was right - when you have the VPN connected ALL traffic not destined for you local network is going via the university. That is particularly obvious if you compare your trace to the Plusnet time server to mine; yours you can see goes via the university, then out on to the Janet network before it reaches Plusnet.
Don't know if this is totally true.. most of my traffic goes through VPN cause most of my traffic is searching papers and using softwares that NEED University server to have access to it, so it doesn't mean much... and this also reply to your question on how much I need VPN! is there any traffic at going through VPN all not ? I only occasionally waste some time on facebook.. and check this forum!!
Quote from: jelv ping -n 50 152.78.0.30
VPN connected results:
Esecuzione di Ping 152.78.0.30 con 32 byte di dati:
Risposta da 152.78.0.30: byte=32 durata=62ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=154ms TTL=250
Richiesta scaduta.
Risposta da 152.78.0.30: byte=32 durata=69ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=74ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=84ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=43ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=71ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=45ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=33ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=81ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=77ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=53ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=36ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=65ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=73ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=94ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=54ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=67ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=72ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=42ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=82ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=55ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=68ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=87ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=107ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=70ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=39ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=90ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=135ms TTL=250
Risposta da 152.78.0.30: byte=32 durata=144ms TTL=250
Statistiche Ping per 152.78.0.30:
Pacchetti: Trasmessi = 50, Ricevuti = 49, Persi = 1 (2% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
Minimo = 33ms, Massimo = 154ms, Medio = 71ms
VPN Disconnected
C:\WINDOWS\system32>ping -n 50 152.78.0.30
Risposta da 152.78.0.30: byte=32 durata=38ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=43ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=32ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=37ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=31ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=35ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=34ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=44ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=41ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=74ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=73ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=36ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=42ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=33ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=103ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=91ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=89ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=77ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=79ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=59ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=75ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=143ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=167ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=63ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=62ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=122ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=121ms TTL=245
Risposta da 152.78.0.30: byte=32 durata=142ms TTL=245
Pacchetti: Trasmessi = 50, Ricevuti = 50, Persi = 0 (0% persi),
Minimo = 31ms, Massimo = 167ms, Medio = 57ms
