Disconnections.
Laura1975
Re: Disconnections.
Quote from: MisterW
Not sure which VPN client you are using , but if its a standard VPN connection using the Windows PPTP VPN client then you can configure it not to route all the traffic through the VPN, and only that which is destined for the remote network will go through the VPN tunnel. See here http://knowledgelayer.softlayer.com/questions/212/Setting+up+PPTP+for+Windows+XP , its the 'Uncheck Use default gateway on remote network' you need to do, see Fig 15 ( about 2/3 down the link ).
Unchecked!!! Thanks! Hopefully it will understand when use VPN and when not... I'll monitor how it goes.
Unless suddenly something goes wrong I'd say to get updated tomorrow cause today connection seems reliable... no disconnections till now!
jelv
Fixes: 10
Re: Disconnections.
Without the VPN connected I'd expect your pings to be similar to mine - but they are not:
C:\Documents and Settings\John>ping -n 50 152.78.0.30
Pinging 152.78.0.30 with 32 bytes of data:
Reply from 152.78.0.30: bytes=32 time=15ms TTL=245
Reply from 152.78.0.30: bytes=32 time=14ms TTL=245
Reply from 152.78.0.30: bytes=32 time=23ms TTL=245
Reply from 152.78.0.30: bytes=32 time=25ms TTL=245
Reply from 152.78.0.30: bytes=32 time=45ms TTL=245
Reply from 152.78.0.30: bytes=32 time=16ms TTL=245
Reply from 152.78.0.30: bytes=32 time=13ms TTL=245
Reply from 152.78.0.30: bytes=32 time=22ms TTL=245
Reply from 152.78.0.30: bytes=32 time=65ms TTL=245
Reply from 152.78.0.30: bytes=32 time=18ms TTL=245
Reply from 152.78.0.30: bytes=32 time=39ms TTL=245
Reply from 152.78.0.30: bytes=32 time=19ms TTL=245
Ping statistics for 152.78.0.30:
   Packets: Sent = 50, Received = 50, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 13ms, Maximum = 65ms, Average = 17ms
I've just checked back and see that you are in London. As the Plusnet gateways we all connect through are in London (where Plusnet peer with the Janet network) I'd actually expect your latency to be better than mine (I'm near Brighton).
Were those tests using a wired or wireless connection to the router?
If we can pin down why your latency is so much higher and so variable I think we might get somewhere. If you start getting disconnections again can you repeat the ping test without the VPN connected please to see if the latency is looking different.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jelv
Fixes: 10
Re: Disconnections.
Quote from: Laura1975
Quote from: MisterW
If you now run the tracert ntp.plus.net again with the VPN connected we should see a difference (it should give the same path irrespective of whether the VPN is connected).
If you've got that working correctly it will help us immensely - you will be able to check if you can still access the internet when the VPN drops out.
Laura1975
Re: Disconnections.
Quote from: jelv
I'm running only wired (wireless off) just to avoid other factors. I've also run the ping again and it is very similar now with or without VPN, but still close to the VPN off values as before (apart for one jump at 150 ms).
Statistiche Ping per 152.78.0.30:
    Pacchetti: Trasmessi = 50, Ricevuti = 43, Persi = 7 (14% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
    Minimo = 33ms, Massimo =  150ms, Medio =  40ms
I'll run the ping again if disconnections start again.
Quote from: jelv
run and it's the same with or without VPN:
Microsoft Windows XP [Versione 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Me>cd \windows\system32\
C:\WINDOWS\system32>tracert ntp.plus.net
Rilevazione instradamento verso ntp.plus.net [212.159.13.49]
su un massimo di 30 punti di passaggio:
  1    <1 ms    <1 ms    <1 ms  192.168.0.1
  2    30 ms    29 ms    29 ms  lo0-central2.ptn-ag01.plus.net [195.166.128.203]
  3    30 ms    32 ms    30 ms  gi2-11-121.ptn-gw01.plus.net [84.92.3.145]
  4    54 ms    33 ms    32 ms  vl55.ptn-lb01.plus.net [212.159.2.124]
  5    32 ms    30 ms    31 ms  cdns01.plus.net [212.159.13.49]
Rilevazione completata.
VPN DISCONNECTED
Rilevazione instradamento verso ntp.plus.net [212.159.6.10]
  2    29 ms    31 ms    32 ms  lo0-central2.ptn-ag01.plus.net [195.166.128.203]
  3    31 ms    31 ms    32 ms  gi2-11-121.ptn-gw01.plus.net [84.92.3.145]
  4    36 ms    34 ms    34 ms  vl55.ptn-lb01.plus.net [212.159.2.124]
  5    37 ms    41 ms    34 ms  cdns02.plus.net [212.159.6.10]
So that is sorted for now. I still wonder why i didn't have these problems before....
Laura1975
Re: Disconnections.
don't worry about that... it was settling the VPN connection when I enabled it again, that's why i've only put the summary.
bobpullen
Fixes: 316
Re: Disconnections.
Here are your recent connection logs from this side if it helps with your diagnosis:
Session Started	Session Ended	Session Duration
15:43 31/May/2010 N/A One Day, 22:57:53 (on going)
15:34 31/May/2010 15:42 31/May/2010   0:8:11
15:32 31/May/2010 15:33 31/May/2010   0:1:8
15:30 31/May/2010 15:32 31/May/2010   0:1:34
14:54 31/May/2010 15:19 31/May/2010   0:25:2
10:36 28/May/2010 12:26 31/May/2010 3 Days, 1:49:41
10:04 28/May/2010 10:36 28/May/2010   0:32:11
09:17 28/May/2010 10:02 28/May/2010   0:45:3
08:56 28/May/2010 09:17 28/May/2010   0:20:28
03:00 28/May/2010 08:52 28/May/2010   5:52:18
00:45 28/May/2010 03:00 28/May/2010   2:14:42
00:43 28/May/2010 00:45 28/May/2010   0:2:4
00:39 28/May/2010 00:42 28/May/2010   0:3:48
00:29 28/May/2010 00:37 28/May/2010   0:8:14
13:33 27/May/2010 00:27 28/May/2010   10:54:3
jelv
Fixes: 10
Re: Disconnections.
Is that basically the same information as Mand posted graphically here?
Laura1975
Re: Disconnections.
Owww.. they've started again... catched few ones today around noon... anything on the log on plusnet side?Huh
I've been away in the weekend so i don't know if they've only started today.
tried ping (VPN on, "use default gateway..." uncheked, average 32ms with few peaks aorund 100ms).. but too late to catch any of them and now seemed they've stopped.
orbrey
Re: Disconnections.
We saw one today, just before 11am though it looks like a clean disconnect so from our side it seems as if the router was rebooted. That's usually indicative of interference on the internal wiring though. I guess you've tested already from the master socket with all the phones unplugged?
Laura1975
Re: Disconnections.
No, that was me... turning the socket off and on again for other reasons. I've started working after that and had the jumping thing again...
I've contacted the VPN people to check, they're not having problems on their side either, but I've asked them if they can help me understand if it's the vpn only or the connection that jumps. let's see what we come up with.
jelv
Fixes: 10
Re: Disconnections.
With the configuration change you made to the VPN you should still be able to use the internet when the VPN drops - can you confirm whether you saw that or not?
Laura1975
Re: Disconnections.
Not yet.. it's not really easy... I had to restore the previous setting otherwise ISI website doesn't recognise me. So when the disconnections start I have to change them back and start with the refreshing page routine until I overlap one of the disconnection... I didn't manage to do that until now!
... and my deadline is in a week...
Cry
if I found out that it's plusnet fault i'll make their crash my life mission... it's almost a month now that i deal with this rubbish...
jelv
Fixes: 10
Re: Disconnections.
Laura, I'm almost certain that it is the VPN software not handling marginal timing correctly. The reason I'm so confident is that about 3 years ago I was experiencing very similar problems. I spent ages working with the Plusnet support doing comprehensive Wireshark traces of my line, I had to change my network topology to do so and run a separate monitoring PC. At the end of it nothing was ever found that pointed to a fault on the Plusnet network.
Two things did make a difference. Firstly I went on to the Max Premium trial (details accessible from here). This mainly provides for higher upload speeds than standard Max (up to 832kbps which may be beneficial to you anyway if you have to upload large files or send emails with large attachments), but it also gives all your traffic a higher priority on the BT network. That made a significant improvement. If you do decide to give that a try post back as the ticket pool requests for Max Premium go in to is not looked at on a daily basis - we'll need to give one of the Comms team a prod to get it done quickly.
The second thing that made a huge difference the organisation changed to a different VPN gateway/software package - all remaining problems disappeared overnight!
Edit: There used to be a link to the Max Premium FAQs from the page I linked. Sad You can read them here: http://www.plus.net/support/broadband/products/faqs_and_guides/max_premium.shtml
2. Who is Max Premium designed for?
It's designed for businesses and individuals who do large amounts of uploading, or need to upload files at a faster speed than normal. Max Premium is particularly suited for VPN use.
Laura1975
Re: Disconnections.
Jalv, I understand your experience, but in my case there are other things that are not clear to me and make me doubt about your diagnosis. As a doctor asks when you feel sick "when did that started?" I wondered the same. I've never had problems until I moved in this new place and applied to plusnet. If I move somewhere else I see no problems too.
So logic wants that it's either the connection or the wiring in the house, and if I'm not wrong they're both plusnet responsability.
About the software, I cannot change it as it is installed on my pc using a standard windows connection setup.
About the upgrade, first I'm reluctant to spend more money on this company... I'm instead thinking of leaving it cause to me it doesn't look very professional... (I don't fly ryanair anymore because I don't like their hidden costs and if you add that you end up paying as all the others). Secondly the connection speed both in download and upload have been measured also at my sister's place (where I have no problem) and they don't differ much, at least in steady conditions .. of course I cannot check if there are big oscillations, but nothing would prevent big spikes happening also with upgraded contract.
Overall it is not good for plusnet to keep problems on going, because it's almost a month that I'm telling all bad things about Plusnet on facebook and by words of mouth just because I'm constantly upset.
The worst thing is that even the disconnections are unreliable, so even if i upgrade and it goes well for a while who can guarantee that it's going to work?!!!! Today seems fine but i now feel like I cannot relax...
itsme
Re: Disconnections.
Max Premium is a BT option which PN pass on the cost with very little or no mark up. So it not a way for them to make more money as your comparison with RyanAir. When you connect to the exchange you are using Virtual Paths (VP) and this is more than likely where congestion is seen and delays are experienced that can cause you VPN connection to drop. Max Premium give you higher priority and therefore less likely delays are seen. Your sister could be on an exchange were the VP are not congested. From reading other VPN's problem it seem that there is a bit of a black act to get to the bottom of the problems.
