Connection acting like it's throttled?!
- Connection acting like it's throttled?!
15-04-2009 11:34 AM
First post here as Plus.net support seems to be taking longer to get back to me by the day.
We're on the old Premier account.
Firstly during the Peak hours of 4pm to 12pm our connection runs at dialup speeds, pings are fine, we get 36ms to the Speedtest.net server, it's just that you can't really even browse the net properly, never mind watch something on iPlayer or even view a YouTube video.
After 12pm things are okay. I reported a speed problem to Plusnet, they said that our line was an old fixed 1Mb. So they've moved us to MAX, we now get a sync of 3392 Kbps downstream and 448 Kbps upstream. However, even during non-peak hours we get a maxium download speed of 115Kb/s.
We are DEFINATELY not being throttled, out billing reset on the 11th and we've only used 3.1GB peak usage since then.
As I said, I wouldn't normally complain on a forum, but Plusnet support tickets are now taking far longer than usual to reply.
Many Thanks!
Re: Connection acting like it's throttled?!
15-04-2009 1:01 PM
Quote maxium download speed of 115Kb/s.
is this a bt speed test? if so have you used other tester sites and what do these report
15-04-2009 1:07 PM
5 parts, a 100mb Zip file for testing. Normally I find Rapidshare will max any connection.
Just had this support reply though:
Dear Mr Webb,
I have now amended your connection profile on our systems to match those of BT's systems. Please can you retest the line and let us know if you have further problems.
[Internal]
Upstream Link Info
Loop Loss Loop Loss Add Text SNR Margin Errored Seconds HecErrors Cell Count Speed
37 17 39 0 -763540418 448
Downstream Link Info
Loop Loss Loop Loss Add Text SNR Margin ErroredSeconds HecErrors CellCount Speed
63 6 0 0 -1624558247 3392
DSL Max Data
BIP Interface Data
Current line rate Line rate change timestamp Maximum Stable Rate Recalcuated ProfileTimestamp Maximum Stable Rate
2500 2009-04-15T03:02:24 1111-01-01T00:00:00
Kind regards,
link:CSA Removed
HOWEVER! This does not explain the ultra slow speeds during Peak hours.
jim:red Agents name removed mod:end
15-04-2009 1:46 PM
What kind of speeds are you seeing on a normal speedtest? eg www.mybroadbandspeed.co.uk or www.speedtest.net ?
15-04-2009 2:22 PM
I have the iPhone SpeedTest app that I also used as well as the PC website one. It shows that on the 13th of April at 22:55:52, with no other devices connected to the router that the speed of the internet was 120kbps down and 60kbps up.
On the 14th of April at 00:15:33, with no other devices connected to the router that the speed of the internet was 891kbps down and 238kbps up.
The results are almost exactly the same on the website version, I just can't test it at the moment as I'm at work.
15-04-2009 5:15 PM
At home now, look at this! Nothing is connected to the router but my PC and my iPhone.
Date Download Speed Upload Speed
Today 17:13 128 kbps (16kB/s) 58 kbps (7.25kB/s)
Today 08:29 916 kbps (115kB/s) 323 kbps (40.4kB/s)
Yesterday 22:38 133 kbps (16.6kB/s) 42 kbps (5.25kB/s)
My support ticket ID: 28482954
15-04-2009 5:25 PM
If the speeds are still slow, do the following:
Run the BT Speedtest at: http://speedtest.bt.com and post the FULL results. If it fails to complete, it should at least give you the IP Profile.
Also, pleae post the contents of this page
Finally, it may be worthwhile raising a ticket and asking PN to provide your recent sync history.
Post back with these, (certainly the first two while pending the third)
Cheers
B.
15-04-2009 5:28 PM
15-04-2009 5:31 PM
15-04-2009 5:37 PM
I've rebooted the router twice now since I've been home from work.
Here are the results of the speedtest:
And the results from that page:
15-04-2009 5:41 PM
Can you explain why my connection was being restricted?
16-04-2009 10:01 AM
Good to hear it's back to normal speed and sorry it happened in the first place.
17-04-2009 10:06 AM
20-04-2009 9:44 AM
Can I get 2.29Mb/s back please? Thanks. lol
20-04-2009 11:29 AM
