Cannot Seed
- Cannot Seed
Cannot Seed
28-09-2007 10:13 AM
I have no problem d/loading on P2P however I cannot connect to peers when seeding.I have checked Port Opening and get the following message.......OK! Port 37378 is open and accepting connections.
You will be able to receive incoming BitTorrent connections..
Can anyone advise?
Can anyone advise?
Message 1 of 7
(1,826 Views)
6 REPLIES 6
Re: Cannot Seed
28-09-2007 11:22 AM
Sound like an issue with your P2P client or perhaps the limited bandwidth available for traffic upstream... What P2P client are you trying to use?
DM.
DM.
KABOOM!
Message 2 of 7
(600 Views)
Re: Cannot Seed
28-09-2007 1:22 PM
I mainly use utorrent but it's also happening on azureus.My router firewall service setting is TCP/UDP which I understand should open both incoming and outgoing on port 37378 and 52000 respectively.
Message 3 of 7
(600 Views)
Re: Cannot Seed
28-09-2007 1:27 PM
How long has this been a problem for? I'm seeing a fair amount of usage on P2P on your account. Has it only just started happening?
Message 4 of 7
(600 Views)
Re: Cannot Seed
28-09-2007 1:48 PM
Hi James,yes it has only recently started happening.
Message 5 of 7
(600 Views)
Re: Cannot Seed
28-09-2007 1:50 PM
Randomness! Can you try using a different port on uTorrent?
It's not apparently a traffic management issue as you haven't hit your usage allocation.
Message 6 of 7
(600 Views)
Re: Cannot Seed
28-09-2007 2:10 PM
OK James,will do.Thanks for all replies.
Message 7 of 7
(600 Views)
