Can you add a second wireless router?
- Can you add a second wireless router?
- « Previous
- 1
- 2
- Next »
Re: Can you add a second wireless router?
23-05-2012 10:22 AM
Grudkin
Thanks for your response.
As I have already got network outlets hard wired in the part of the house where I wish to locate the second router, this solution would be ideal if I can set it up - new to networking so on a steep learning curve.
Would it be best to use two routers of the same make or would it be possible to use any make of router as the second router?
Message 16 of 19
(447 Views)
23-05-2012 10:30 AM
If you've got wiring you need to buy a WAP - Wireless Access Point.
They are designed to do EXACTLY what you want and connect back to a LAN port on your main ADSL Modem/Router.
Brand isn't important.
Message 17 of 19
(447 Views)
23-05-2012 10:41 AM
The beauty of using a WAP is that all the complications like setting IP addresses, DHCP severs, DNS servers are taken out of the equation. Your router will continue to handle all those aspects, the WAP just enables you to get wireless connections in another location.
Edit: Ye Gods! I didn't realise how much the price of things had come down. No idea if it is any good but... http://www.amazon.co.uk/TP-Link-TL-WA701ND-150Mbps-Wireless-Access/dp/B002YETVVE/ref=sr_1_2?s=comput...
Message 18 of 19
(447 Views)
23-05-2012 10:48 AM
I set up a second router / wireless access point, the instructions are on a thread called Can I use TG585 as a wireless access point?
Message 19 of 19
(447 Views)
- « Previous
- 1
- 2
- Next »
