Can't connect to wifi
Jamie37
A BT Openreach Technician came round at about 12 to activate my wifi the light on the Hub one is blue but when I try to connect to it it, it doesn't connect it just comes up with settings and advanced settings. The man said it would activate in 10mins-1hr but it still hasn't
14 REPLIES 14
Fixes: 1,601
Re: Can't connect to wifi
Sorry to hear you're not able to get online.
As per my response on your last thread, it can take anytime up to midnight for the service to go live. However, I've checked your order and it's showing as completed so I've manually activated your account now.
Let us know how you get on.
Jamie37
@Gandalf Thank you but it shows this when I click my wifi
Fixes: 1,601
Can you try connecting using yourusername@plusdsl.net and your account password?
MatthewWheeler
Fixes: 480
Can you try going through the steps below?
1) Enter 192.168.1.254 in your web browser
2) Click settings and then enter the router password (This can be found on the bottom of the router or on the card provided with the router)
3) Click on broadband and then click the disconnect button
4) Delete the username and replace it with yourusername@plusdsl.net and then enter your account password in the password field
5) Click connect and wait 2 minutes. You should then be able to get online
 Matthew Wheeler
Jamie37
@Gandalf no, it just says admin password but I log into admin account but it just shows device list and parental controls
Fixes: 1,601
Have you tried the steps @MatthewWheeler posted?
Jamie37
Ok I will try now I accidentally pressed fixed @matthewheeler @Gandalf
Fixes: 1,601
No problems, let us know if you can't get online and we'll get that unfixed for you.
Jamie37
It comes up with a blank page when I type the address thing @MatthewWheeler @Gandalf
Fixes: 1,601
Are you typing the address whilst connected to the WiFi or via a wired connection to the router?
Jamie37
EE 4G @Gandalf
Jamie37
@Gandalf It says PPP Conecting then brings me back to the login page also the broadband light is back on my router now
Jamie37
@MatthewWheeler after these steps it says you are already connected tho broadband no further setup is needed
MatthewWheeler
Fixes: 480
It looks like you've been entering the incorrect password.
 Matthew Wheeler
