BT speed checker U/S for several days
- BT speed checker U/S for several days
Re: BT speed checker U/S for several days
02-03-2011 9:44 AM
edgeways.
02-03-2011 9:47 AM
02-03-2011 9:51 AM
Quote Download speedachieved during the test was - 6073 Kbps
For your connection, the acceptable range of speeds is 1200-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 832 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
That looks a lot better than yesterday's test! IT can in a reasonable time as well.
02-03-2011 9:52 AM
02-03-2011 10:26 AM
02-03-2011 12:15 PM
02-03-2011 12:41 PM
Operating system: Windows 7 64 bit
Web browser/Version in use: Google Chrome version 9.0.597.107
Antivirus/Security software in use: Kaspersky Internet Security version 11.0.2.556 (a.b.c.d)
Router make/model and whether wired/wireless: Billion Bipac 7800N wired
Java version: version 6 update 24 (both 32 bit and 64 bit versions)
Error message/Description of problem: After clicking GO and confirming my phone number it sits for two minutes and then produces the following error message 'TEST ERROR The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Time and date the error was encountered: 12:35pm 2nd March 2011
02-03-2011 1:19 PM
02-03-2011 3:39 PM
02-03-2011 3:44 PM
Closing the password box, without entering my password then takes me to http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=1&l1=0 where I receive the message "HTTP/1.0 401 Authorization Required."
Note to self: Must stop thinking aloud.
02-03-2011 3:52 PM
Quote from: linux I tried disabling the firewall on my router (should be OK since my PC has no open listening ports) and tried the test again. It still failed. Since I don't use antivirus or any other firewall, my feeling is that this problem is not related to antivirus/firewall software.
Yes linux, I aggree with your conclusion. I have previously tried similar measures with the same negative results.
02-03-2011 4:13 PM
02-03-2011 4:17 PM
But it might prove conclusively whether or not this is a simple accounting bug.
Why does the BT speed tester need a telephone number or service ID? The world wonders.
02-03-2011 4:20 PM
02-03-2011 4:23 PM
