Authentication issue...
- Authentication issue...
24-10-2007 3:24 PM
I understand that there was some maintanance done over this morning, and that I was going to be disconnected because of it (I'm on BYW Option 3). I'm not too sure if I was part of the bunch of users that were going to get disconnected, but, apparently, I was.
The problem is that the maintanance should've been over by now, and I'm still disconnected. I have rebooted my router with no luck. Is anybody else having the same problem?
Caleb
Caleb
Message 1 of 5
(1,241 Views)
4 REPLIES 4
Re: Authentication issue...
24-10-2007 3:27 PM
Everyone was disconnected this morning to ensure that our pipes were balanced.
Could I possibly ask you to unplug your router for approximately 15-20 minutes and then try reconnecting to see if this improves your situation?
Message 2 of 5
(459 Views)
24-10-2007 3:29 PM
Thanks.
I'll do that when I get home. Hope it works.
Caleb
Caleb
Message 3 of 5
(459 Views)
24-10-2007 3:32 PM
It should work, however you will probably find your speed is slow as you appear to have hit the usage allowance. I spotted a problem on your account which would have been stopping data transfer once you hit the allowance and corrected this.
Message 4 of 5
(459 Views)
24-10-2007 4:56 PM
Yes, it did work. I'm sending this reply from my home. Thank you!
For the other issue, well, it's a whole topic onto itself, I'll start another thread for it. Thanks for your help, though.
Caleb
Caleb
Message 5 of 5
(459 Views)
