Annoying noise coming from router
- Re: Annoying noise coming from router
19-10-2013 10:55 AM
Hello,
My Plusnet connection was set up yesterday and so far I'm very happy with it. I set up my router (Technicolor TG582n) yesterday afternoon and spent the rest of the day online, no problems. However, when I turned the computer off I noticed that the router seems to make a very annoying high pitched noise. I think the power supply buzzes a little, too. This wouldn't be an issue, but the only place in the house that has room for my computer is my bedroom, so the router also has to go in my bedroom. Which means the noise the router is making at night isn't particularly welcome.
Is the router supposed to do this? If not, will I be able to get a replacement? If I have to buy my own replacement, what sort of router would give me the same performance as the one supplied?
Thanks.
Thanks.
Message 1 of 8
(1,706 Views)
7 REPLIES 7
19-10-2013 10:57 AM
It's a known problem and you should be able to get a replacement.
Message 2 of 8
(966 Views)
20-10-2013 8:47 AM
See the thread here http://community.plus.net/forum/index.php/topic,114585.96.html .
Message 3 of 8
(966 Views)
20-10-2013 9:45 AM
Ah, thanks. Time to contact customer services, I suppose. I think they'll be getting annoyed with me, third time I've contacted them in three days.
(Although this is the only time there's been an actual fault and they've been polite and helpful so far. :))
Message 4 of 8
(966 Views)
21-10-2013 1:24 PM
I've flagged this with our products team who'll arrange getting a router to you, I'll update your ticket too.
Message 5 of 8
(966 Views)
23-10-2013 1:02 AM
Awesome, thank you.
Any idea how long it usually takes for a new router to get sent out, out of curiosity?
adie:quote
adie:quote
Message 6 of 8
(966 Views)
23-10-2013 12:58 PM
This had been picked up yesterday by them so you should receive it anyday.
Message 7 of 8
(966 Views)
23-10-2013 5:57 PM
Brilliant, thanks.
Message 8 of 8
(966 Views)
