Am I being paranoid
- Am I being paranoid
Am I being paranoid
09-02-2009 8:19 PM
Statistics Downstream Upstream
Line Rate 8096 Kbps 448 Kbps
Noise Margin 7.6 dB 24.0 dB
Line Attenuation 4.0 dB 1.0 dB
Output Power 7.8 dBm 12.6 dBm
I'm asking if this is temp, I had the same with tiscali, the first year good then things went wrong, some do download ok but the speeds on downloads are not my usual.
regards
Re: Am I being paranoid
09-02-2009 10:53 PM
I've just tried a download from here and it's coming down between 60-80kB/s (480-640kbps). Looks like it's in the gold traffic queues too so not sure what could be causing your problem. Do you know what your IP Profile is and have you tried a BT speedtest?
09-02-2009 11:02 PM
10-02-2009 10:11 AM
regards
john
10-02-2009 10:13 AM
The username for the BT speedtest will be username@plusdsl.net
10-02-2009 10:17 AM
regards
john
10-02-2009 10:21 AM
I suspect it may have been partly related to your being connected to a "busier" pipe last night, compounded by a pipe drop we experience around dinner time* last night.
If it happens again, I'd definitely recommend rebooting and see if you get better speeds.
*Southern dinner time. ie: not lunch.
10-02-2009 10:28 AM
est1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8096 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7000 kbps
Actual IP throughput achieved during the test was - 6353 kbps
Everything looks OK to me, could the problem be that my router has not been rebooted for some 21 days and previous to that I think it was longer, I have not been on that much due to illness, would you recommend rebooting router every week or so ? Could that be be the problem ?
regards
10-02-2009 10:29 AM
I'd just say to reboot your router if you feel that your speeds aren't what you would expect.
I hope you're feeling better now.
10-02-2009 6:52 PM
I'm not in the best of health at all, just get bad days, some worse than others, just got to plod on.
kind regards
