ADSL Speeds Issues
- Re: ADSL Speeds Issues
04-02-2021 10:19 AM
Sorry to hear of your multiple troubles, Keith. From my quick look at the D7800 guide last night, your failure to find that really useful info doesn't surprise me - they seem to be removing useful features on new gear, while introducing many that most users don't want, or need..
Yes, the 2704N will give that data, thankfully.
Is it just you that's down, do you know, or is it an area-wide thing? If you give your phone area code, I could check?
04-02-2021 10:20 AM
I think its just us, but i dont know for sure... I'll ask about, it's a small village / hamlet so that shouldnt be a difficult to find out.
The area code is 01389, but that covers a significant physical area, of which we are a very small section.
04-02-2021 10:29 AM
No area-wide reports showing, so it probably is just you - sorry.
04-02-2021 10:39 AM
Morning @keithdwilliams
I am sorry to hear about the loss of connection, I can confirm that we have located an external fault on your line that is impacting your services. Our Suppliers have advised an estimated response time of 08/02/21 23:59:59, I have logged the fault on your account here to be reviewed by the Faults Team following that timescale
04-02-2021 10:42 AM
@jab1 Although Netgear GUI information is limited, there is more info than most people know what to do with if you telnet to them.
Some would say a D7800 is overkill for a long ADSL line, but each to their own.
@keithdwilliams you really need to get your phone line sorted before trying to get higher speeds on broadband.
04-02-2021 10:44 AM
thanks @tinytaco
i dont mean to sound precocious, but, the 8th is 4 days away?! is that the longest i would wait?
04-02-2021 10:48 AM
OK @Mustrum , I'll take your word for that - re the information, but I recall on my DG834 you didn't have telnet - it was just there - easy to access and easy to understand. These days, it seems that basic data is hidden, as though they don't want you to be able to easily find it.
Makes it hard to help yourself, if you are capable, or others, if they need guidance.
04-02-2021 10:48 AM
Hi @keithdwilliams it is the longest you'll have to wait for an engineer to respond to the job, they tend to come out before that 😊(don't hold me to that though, ha! 🤣)
04-02-2021 10:48 AM
@Mustrum its not a new router, and was bought when the line was shorter - well, for a different location. it has worked very well until this week! i did manage to get into telnet, but i couldn';t any description of the commands the CLI uses to output anything meaningful - is there a description somewhere? its a BusyBox OS - i think - i'd be very interested in seeing something. when we're back up and running!
as for the line, there's a fault... when we sort that, i'll worry about the rest!
04-02-2021 10:49 AM
thanks @tinytaco
04-02-2021 11:09 AM
@keithdwilliams I have a D7000 which i have been very pleased with, I use DSLstats to monitor it, and chose this model over the D7800 as I knew DSLstats worked. AS such I have to look up commands if i want to use them, but the basic output from it is:
adslctl info --stats
adslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 24429 Kbps, Downstream rate = 76771 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 75335 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.3 9.2
Attn(dB): 8.6 0.0
Pwr(dBm): -9.0 -9.0
VDSL2 framing
Bearer 0
MSGc: 18 150
B: 239 236
M: 1 1
T: 22 5
R: 0 16
S: 0.1014 0.3771
L: 18936 5410
😧 1 1
I: 240 255
N: 240 255
Counters
Bearer 0
OHF: 589697539 87069
OHFErr: 4120 2634
RS: 0 3861529
RSCorr: 0 26746
RSUnCorr: 0 0
Bearer 0
HEC: 12965 0
OCD: 101 0
LCD: 101 0
Total Cells: 1753079239 0
Data Cells: 771018414 0
Drop Cells: 0
Bit Errors: 0 0
ES: 1569 1595
SES: 2 0
UAS: 27 27
AS: 990390
Bearer 0
INP: 0.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 1.67 6.15
OR: 114.31 202.87
AgR: 75449.27 20203.27
Bitswap: 2254/2462 515/516
Total time = 11 days 11 hours 6 min 57 sec
FEC: 0 26746
CRC: 4120 2634
ES: 1569 1595
SES: 2 0
UAS: 27 27
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Latest 15 minutes time = 6 min 57 sec
FEC: 0 6
CRC: 0 1
ES: 0 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 9
CRC: 23 1
ES: 3 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: N/A
Latest 1 day time = 11 hours 6 min 57 sec
FEC: 0 799
CRC: 95 95
ES: 42 56
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 1 day time = 24 hours 0 sec
FEC: 0 1442
CRC: 167 154
ES: 122 123
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Since Link time = 11 days 11 hours 6 min 29 sec
FEC: 0 26746
CRC: 4120 2634
ES: 1569 1595
SES: 2 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
05-02-2021 12:49 PM
@tinytaco i think BT, or their associate company, tried to call the landline - which is almost entirely dead now - and i missed them. I have no way to call them back or contact them - do i need to? Or will they come back to me?
05-02-2021 12:55 PM
@keithdwilliams Do you know the number that called you? If so, call it back on your mobile?
05-02-2021 3:09 PM
I guess patience is the name of the game.
05-02-2021 3:15 PM
OK Keith - don't know them, but I SUPPOSE they could be BT subcontractors.
