2 months and no stable connection
- 2 months and no stable connection
Re: 2 months and no stable connection
21-07-2010 10:34 AM
Glad you are back on board with this. I have added a few days worth of speed results on my open question so you can see the sudden drop as of yesterday.
Just to update you as of now:
connection 2464kbps
download 1.8mbps
connected for 16.5 hours
Line attenuation reads 57db with noise margin of 12.1db on the downstream.
Hopefully the last day or so was just a hiccup, but I won't start jumping for joy just yet.
Thanks,
P
22-07-2010 8:10 AM
Not a glitch, last night I couldn't even get to check my emails as the download was so slow. a 23kb email took nearly TEN minutes to download, and every time I tried to open a web page ittook for ever and then would flag up that it was unable to connect.
This morning better though 1.6mbps download, but for how long?
P.
22-07-2010 9:05 AM
I know this must be immensely frustrating but I cant' give you a specific timescale as much as I'd love to be able to.
As things stand the speeds will be quite poor as a result of your connection dropping again so we'll need to get to the bottom of that issue first. I don't have much to tell just yet but I will be pushing for a response from BT wholesale today so I'll give you a call later on to keep you abreast of what's happening on that side of things.
22-07-2010 5:23 PM
As per my voice mail the good news is that engineers need to replace part of your line to resolve the fault. This is due to happen tomorrow morning. If you look out after 9AM Openreach engineers should be accessing the local telegraphs with a cherry-picker.
Any questions please let me know, otherwise I'll come back to you after 11:00AM tomorrow.
22-07-2010 7:08 PM
Thanks for the heads up about BT coming tomorrow. Sorry not to take your call I was driving so won't answer if my mobile rings as I don't even like the hands free gizmos.
Can you find out what exactly they will have done before you call me, as tonight I'm getting 1.6mbps download and connection of 2592kbps and it's been a stable connection for nearly 19 hours, I don't want to find that tomorrow it's all cocked up by BT again, like once before.
Many thanks,
P.
23-07-2010 9:34 AM
24-07-2010 9:31 AM
All seems fine since bt visit yesterday, except that I'm connected at 2784kbps but my profile is only 1750kbps, so my download speed is only 1.6mbps.
I would like to get back to at least a 2000kbps profile if not a 2500kbps as I had when the problem was first fixed a couple of weeks back. Should I reboot the router? or is there anything you can do at your end?
Luckily I was home when bt came as they needed to access my property, all they said was that they were trying to reset a new pairing and moving me into the exchange????
Anyway hope to hear from you on Monday.
P
26-07-2010 10:11 AM
I've just checked on the fault and the engineer's notes aren't showing yet - if there's nothing by lunchtime I'll call and chase them for you so we can see what went on from their point of view.
From yours, how is the line performing now? I can see you've had a solid connection for the past couple of days, and have just upped your PN profile to 2000 to match that set on the BT side of things.
26-07-2010 11:00 AM
As of now router stats show connection of only 37 minutes, but line connection speed is 2784kbps which I've had for the weekend.
Download speed is 1.7mbps
I have done a speedtest at myspeed at visualware, and that says my download is 1.8 mbps of 2.4mbps.
So can I get a 2meg download or am I stuck at 1.7?
Obviously I would prefer the faster speed, but is that ever going to possible on our ancient exchange?
Many thanks,
P.
26-07-2010 1:48 PM
27-07-2010 10:13 PM
Tonight I lost connection on my router several times but I think it may have been due to my doing a clean install of win7 64bit.
All seems ok now.
P
28-07-2010 9:41 AM
28-07-2010 2:57 PM
As per my update to your ticket I'm unable to get the exact notes from the 23rd's engineer visit due to some problems on the suppliers side. I'll be in touch as soon as I can tell you more.
Thanks for your patience,
Adam.
28-07-2010 3:14 PM
All seems ok, but that's waht I thought last week.
Would prefer to see the profile back to 2500kbps, but suppose I should be grateful for any speed out in the sticks.
P.
28-07-2010 4:11 PM
The 2500kbps line rate should return when the connection has been running for 3 days in a row. Unfortunately your connection hasn't quite hit that yet but I'm hoping that I can tell you more when I've been able to have a chat with BT.
