IP Profile increasing?
Barrytrcy
IP profile has jumped from 2000 to 2500. Does this mean it will keep increasing?
I reset my router a few days back, IP profile fell from 3000 to 2000 now 3 days later it has increased from 2000 to 2500.
Cheers.
pierre_pierre
Re: IP Profile increasing?
It could do
Barrytrcy
Quote from: pierre_pierre
It could do
Man of few words  Cheesy
jojopillo
Hi Barrytrcy,
I've just ran a line test and with your current sync rate of 2912k the 2500 profile is the maximum you can get. You've done the best thing raising a fault, especially if you're in the test socket, as the attenuation of 37 should give you a much better sync rate. Even your SNR at 13dB would only bring it down by about 1600k so I would still expect to see at least 5-5500k sync.
Jojo Smiley
