win 7 to win 10 question
- win 7 to win 10 question
26-09-2015 12:25 PM
So my question do i ignore those updates and try to download windows 10 or do i update windows 7 first ?
Re: win 7 to win 10 question
26-09-2015 12:32 PM
26-09-2015 12:34 PM
26-09-2015 1:11 PM
York.
26-09-2015 2:29 PM
http://www.microsoft.com/en-gb/software-download/windows10
26-09-2015 2:45 PM
@rongtw .. ive installed win 7 updates now, think ill hold off until parents get fibre installed next week then it be easy to download everything. Having there connection upgraded from 1 meg adsl to 40 meg fttp, i think u have fttp dont you ? mine at home is fttc but still not bad speeds
26-09-2015 9:56 PM
Quote from: St3 do i ignore those updates and try to download windows 10 or do i update windows 7 first ?
The question really amounts to:
"Are there any updates to Windows 7 that will make the Windows 10 update run more smoothly?"
AFAIK the answer is no.
26-09-2015 10:02 PM
26-09-2015 10:07 PM
Edit: Or at least that's the stated description of the update. But it may have been one of those updates that breaks people's computers, or was claimed to be evil and snoops on you.
27-09-2015 8:57 AM
27-09-2015 11:24 AM
