safari browser
pin2011
safari browser
I dwnloaded safari and it starts up in new window but then thats it!! It just hangs forever with that damn cirle thing rotating endlessly. Chrome loads and runs in seconds so whats wrong with apple safari?
8 REPLIES 8
Fixes: 1,485
Re: safari browser
What operating system are you using?
Re: safari browser
On my iMac, OSX 10.6.8, I use Safari 5.1.2 no problem.
Have you tried re-downloading it, or delete it and use Software Update in the  menu, top left.
Which browser were you using before Safari & Chrome ?
Where are you downloading it from, it comes free with OSX, is it a purchased copy of OSX ?
Fixes: 1,485
Re: safari browser
i suspect it's on windows which is why I asked for which O/S
Re: safari browser
The question was asked in the Mac/Linux software section though, but yes I suspected the same.
If that is the case, I wonder if the correct version for the O/S was downloaded ?
I note he does state the rotating circle of death, AFAIK that is a Mac OSX thing.
pin2011
Re: safari browser
Quote from: dvorak
Windows 7 on an acer i3 350m
pin2011
Re: safari browser
Quote from: PlusComUK
From apple web site for the ninth time after deleting each time before installing
pin2011
Re: safari browser
Just a bit more info The browser was ie9. Add to this my friend has dwnloaded this onto similar pc and it works fine so after numerous attempts to dwnload all the options ie repair files etc I think I'll stay with chrome for the time being.
barky
Re: safari browser
guts of safari & chrome are mush the same (webkit) .... just stick to one you are used to perhaps?
