failure configuring windows updates
- failure configuring windows updates
26-02-2014 8:55 AM
Re: failure configuring windows updates
26-02-2014 9:21 AM
26-02-2014 3:53 PM
26-02-2014 4:19 PM
26-02-2014 10:45 PM
27-02-2014 8:34 AM
27-02-2014 4:15 PM
I had a similar issue a couple of years ago (albeit with W7 pro). When I did each update on its own - rebooting when required - all updates completed without further problem.
Forum Moderator and Customer
01-03-2014 11:42 AM
What worked best for me was to serch for the updates then in the list i clicked the SIZE tab so the biggest files were at the top of the list, I then installed the biggest update first followed by the next few big updates.
After i did that i then chose around 10 files at a time to install and it all worked out good.
03-03-2014 4:23 PM
Have you any joy as yet ?
03-03-2014 5:25 PM
03-03-2014 6:58 PM
Thank you for posting what worked for you
