Sending mail on a mobile connection
Surfer
When away from home, I use "Three" for my mobile connection and can download email no problem however although Three's SMTP does work for sending email, it is rather irregular and sometimes does not work and then you have to hunt for a SMTP thta will work.  Is there any way one can overcome this problem to use the Plus net SMTP to send emails?
1 REPLY 1
jelv
Fixes: 10
Re: Sending mail on a mobile connection
Three don't let you use anybodies SMTP server except their own. You should find http://community.plus.net/forum/index.php/topic,77296.msg622599.html#msg622599 useful.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
