Is Plusnet Attacking Me?
Steve
Seasoned Pro
bearing in mind I am no longer a customer I have been getting DOS Attack from one of your IP addresses. Anyone shed any light? Could It be that I am leaving the forum before the page Is loaded up properly?
Regards
If life gives you lemons, make lemonade.
8 REPLIES 8
bobpullen
Fixes: 316
Re: Is Plusnet Attacking Me?
What host name does a reverse lookup resolve to Steve?
Steve
Seasoned Pro
Hi Bob
community 04.servers.plus.net mean anything to you?
bobpullen
Fixes: 316
84.93.230.178? If so then it's one of our four Community Site boxes.
Steve
Seasoned Pro
Yep that's the one.
bobpullen
Fixes: 316
No suspicious activity on the server Steve so I'd imagine whatever you're seeing is harmless enough.
AlaricAdair
Champion
Not suspicious?  So is it deliberate then?
Now Zen, but a +Net residue.
jelv
Fixes: 10
Quote from: Steve
That's a distinct possibility - do the times seem to tie up?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Steve
Seasoned Pro
@BP Thanks for your time and help. Funnily enough It hasn't happened since I made this thread Crazy
@AlaricAdair I'm not sure I follow?
@Jelv as I said to bob It has not happened since I made this thread, However I haven't been logged into the forum and I have been trying to replicate It but as with everything technical It has a mind of Its own, Logged In now though so will keep an eye on my logs and times I last logged In here at.
Absolutely nothing to worry about though as I don't have a Static IP address. I was more curious really. And I use the Netgear DGN2200 and have read that this can happen If you leave a page before It gets back to you properly, I just have a funny feeling that the latter Is more than likely the case.
TBH I thought It was something fishy with TalkTalk's forum at first as I get this quite a lot and I used to visit that forum regularly too. Haven't checked up the IP address though until now and was surprised to find Plus net's name on It.
But I visit here quite often and there Is times where loading pages takes a while so I give up and leave the page and re-visit several minutes later. Don't usually check my logs until last thing at night (usually when I just want to be nosy though)
Regards
Steve
