IP addresses
- IP addresses
IP addresses
06-11-2015 10:51 PM
Re: IP addresses
06-11-2015 10:57 PM
http://fr.wikiscan.org/plage-ip/81.174.202.0/24?whois=81.174.202.0/24
yours happens to fall into this.
Re: IP addresses
06-11-2015 11:15 PM
That's how I came to notice it.
Funny tho, that the CPanel on my websites report that my login IP is a 46.208.*.* number.
Don't get it!
Re: IP addresses
06-11-2015 11:34 PM
Re: IP addresses
06-11-2015 11:38 PM
Re: IP addresses
07-11-2015 12:12 AM
It's possibly blocked by Whois-Search because lots of users present that proxy IP when doing searches.
(Posted from IP 212.159.*.*)
Re: IP addresses
07-11-2015 12:16 AM
Re: IP addresses
07-11-2015 12:57 AM
Yes, looks that way. Don't understand why I'm getting this 'tunnelling' proxy tho.
(The two instances here are from same computer/browser, btw)
Could be CPanel is storing a previous IP and not caught up yet?
The French whois Dvorak linked to works fine for me tho, so I'll be using that!
Re: IP addresses
07-11-2015 1:27 AM
How often do you log into and out of CPanel? I wondered if that records your IP only when you login.
Re: IP addresses
07-11-2015 2:31 AM
Usually log in to CPanel every day. Couple of times maybe. Its usually there that I notice if the IP has changed.
It changed recently after a power outage and is still showing that IP, not this newer 81.174. one. See if it changes tomorrow.
Only problem was being blocked on WhoisSearch! ("Permanently" apparently! Seems a bit harsh?)
Re: IP addresses
07-11-2015 9:40 AM
Re: IP addresses
07-11-2015 6:38 PM
As for whois. Domain-Tools-whois also ok so no problem
(The error on whois-search seemed to come from RIPE saying " access denied for 2001:41d0:2:bd26:00:0:0:1". Don't know what that means. Is it IPv6-speak or something?)
Re: IP addresses
07-11-2015 7:34 PM
Re: IP addresses
07-11-2015 10:30 PM
So, "access denied for 2001:41d0:2:bd26:00:0:0:1" refers to them!
