Can anyone recommend a ups for my router?
carldrakes
I ordered the https://www.amazon.co.uk/gp/product/B092TG9M7C/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1 but the middle connector was too small for the router pin.
TIA
C
6 REPLIES 6
iannewson
Re: Can anyone recommend a ups for my router?
This is worth a read https://www.speaktothegeek.co.uk/2022/06/review-eaton-3s-mini-dc-ups/ he had the same problem
Fixes: 1,485
Moderators Note
This topic has been moved from Broadband to Tech Help
shutter
Fixes: 65
@carldrakes
This may help....
https://www.youtube.com/watch?v=KxKmdGBdAF8
and this  (skip to 22 seconds to miss the flashy intro!)
https://www.youtube.com/watch?v=iHyA4M0A8V4
carldrakes
Thanks Ian.
carldrakes
Thanks Shutter.
carldrakes
Hi
I've tried measuring the barrel size of the Hub 1 and I come up with 5.5mm x 3mm.  Can anyone confirm if this is right?  Using the technique in the video the tip of the biro is way too small  but if you take the ink bit out and turn in around this seems to fit in the middle of the psu and I've measured that as close to 3mm.
Cheers
C
