Bios password
rongtw
Fixes: 12
Bios password
A quick question , i have a friends laptop needs a reinstall win7 but cant get Into Bios as its pasworded and wont let me boot from disc or USB Sad
so which is easiest way to get into Bios ?  and no its too aquard to get to battery
15 REPLIES 15
ReedRichards
Seasoned Pro
Fixes: 25
Re: Bios password
If your friend set a BIOS password then forgot it there is nothing you can do yourself.  Send the computer to a service agent for the manufacturer with proof of purchase and pay for it to be reset.
A few machines have a default BIOS password set by the manufacturer (!?!) in which case you should be able to look it up.  I had to do this a few months ago; the password was a four digit number that varied according to the date setting.
ejs
Aspiring Hero
Fixes: 25
Re: Bios password
The BIOS password on my old laptop doesn't actually protect the boot menu, you can't get into the BIOS settings without the password, but you can still press the key to get to the boot menu and then choose to boot from a CD or USB.
rongtw
Fixes: 12
Re: Bios password
Its a Old 2005 sony Vaio , it was reset at a shop but he wants £25 to do it again , he reset it to win 10 .
But friend wants win7 but shop put a password on Bios after 3 attempts it lock you out Sad
Tried default Sony Bios pasword 1234567 , plus a few more but no luck Sad
Re: Bios password
@rongtw - Pulling the CMOS battery would be the way to do it but it's not the easiest of tasks. Have you seen this article on the Sony community site? It may, or may not be of use, but worth a read all the same.
shutter
Fixes: 65
Re: Bios password
@rongtw seems to be plenty of options to try on this page...
https://www.google.co.uk/?gws_rd=ssl#q=bios+password+reset
ReedRichards
Seasoned Pro
Fixes: 25
Re: Bios password
That's extortion.  It's not moral for a shop to create a BIOS password and not tell you what it is.  But the charge of £25 seems very reasonable to get a working computer if you have a computer that does not work at the moment.  Is there more to this than your friend is telling you?
A computer from 2005 would have been supplied running Windows XP.  If it ever ran Windows 7 it must have been upgraded.  You will need the licence key for the upgrade to get it back to Windows 7 even after you can access the BIOS.  On the other hand if it can legitimately run Windows 10 (as an upgrade over an upgrade) then you can re-install that without having to find the Windows 7 licence key.
rongtw
Fixes: 12
Re: Bios password
looks like he will have to get password from shop Sad as i dont want ot take it apart to find battery on Motherboard .
It starts in win7 , shuts down saying windows found corrupt files,tried install from win7 but cant wipe disc unless start from boot , but bios is set HD boot only Sad
Hopefully they will give him password
Thanks for all help Smiley
7up
Fixes: 17
Re: Bios password
Forget removing the battery from a laptop to clear the CMOS - that trick hasn't worked for decades. I have an old HP upstairs that I tried it with and it cleared nothing.
Desktop computers yes it usually works but laptops are ultra nickable and so the hardware vendors blocked it moons ago.
I cracked the screen putting the HP back together. Not something I'd recommend to others really.
Strat
Fixes: 565
Re: Bios password
There's often a jumper pin pair on the motherboard that needs shorting to clear the BIOS and load a default.
However opening up a laptop is not something to be done lightly or by the inexperienced.
shutter
Fixes: 65
Re: Bios password
Did you try putting 1234567 into the box on this page?
https://bios-pw.org/
it returns some other passwords, .... but, of course,... if the shop made one up, like the managers birthday, then there is not much hope ...
Here is a video tutorial that may help.....
https://www.youtube.com/watch?v=6EeIPSWhgLc
rongtw
Fixes: 12
Re: Bios password
Cheers yes i did try the default password , and a few other i found , with no Avail Sad
he  is going to shop today see what they say
Re: Bios password
@rongtw - If it's not to late you should ask him to ask them why they reset it in the first place, if I were paying for it I'd have had it removed, never mind reset.
7up
Fixes: 17
Re: Bios password
Again on most desktops yes thats correct but experience has taught me that on laptops thats a myth because otherwise there would be no deterrent against theft.
rongtw
Fixes: 12
Re: Bios password
He called into shop this afternoon, it's run by a young Polish chap ,,,,
Told him his engineer is off sick 😤
