BT Speed Test
Legend
Fixes: 258
BT Speed Test
If this is in the wrong place, can someone move it?
In an attempt to help someone earlier today, I opened the BT speed test page, and just got the background, thought nothing of it, and copied and pasted the link into my reply. To check something on my connection, I have just done the same, and got the same result, so am unable to run a test.
Has the BT Speedtest moved?
12 REPLIES 12
Aspiring Hero
Fixes: 77
Re: BT Speed Test
@jab1 do you mean this? https://speedtest.btwholesale.com
works for me
Dan
Legend
Fixes: 258
Re: BT Speed Test
Yep, @Dan_the_Van - see my resulting 'picture'. NOTE: It has worked previously, and nothing has been changed on my system.
Aspiring Hero
Fixes: 77
Re: BT Speed Test
@jab1 I'm currently using chrome on my Dandroid device, the test runs to it's conclusion.
Lets see how its in the morning
Dan
Legend
Fixes: 258
Re: BT Speed Test
OK @Dan_the_Van FWIW, it runs OK on my iPad, but certainly not on the Linux laptop.
shutter
Fixes: 65
Re: BT Speed Test
@jab1
Linux Mint 21  running on Firefox browser
repeated test immediately after
Tests run using 4gLTE router on SMARTY SIM.
Legend
Fixes: 258
Re: BT Speed Test
Cheers @shutter . I'll have another look in a while, although it is no great issue - I normally use either the TBB or speedtest.net sites, and the actual link still copies and pastes properly.
Browni
Aspiring Hero
Fixes: 60
Re: BT Speed Test
I had that happen a week or so ago, a few presses of F5 fixed it.
Legend
Fixes: 258
Re: BT Speed Test
Cheers @Browni , I'll give a go if I need it. Usually use TBB or Speedtest.net though.
Legend
Fixes: 258
Re: BT Speed Test
Didn't work for me, @Browni . I can only think it is something on the Canonical implementation of the latest FF browser. No problem, though, as I've said before.
Browni
Aspiring Hero
Fixes: 60
Re: BT Speed Test
Have you tried Control-F5?
Legend
Fixes: 258
Re: BT Speed Test
Watch this space. 😉
@Browni - You're a genius - have a 'fix' 👍
Browni
Aspiring Hero
Fixes: 60
Re: BT Speed Test
Cheers John!
Control-F5 forces a complete download of the web page so there must have been something in your cache which didn't work well with the current page.
