Apple OSX 10.9 Mavericks now available..... and it's a FREE Upgrade
- Apple OSX 10.9 Mavericks now available..... and it...
- « Previous
- Next »
Re: Apple OSX 10.9 Mavericks now available..... and it's a FREE Upgrade
25-02-2014 7:54 PM
OSX 10.9.2 update released today 25th February 2014
Available through Software Update, App Store, and macupdate
https://www.macupdate.com/app/mac/48498/os-x-mavericks/10.9.2/1393356711?utm_source=feedburner&utm_m...
What's New
Version 10.9.2:
Adds the ability to make and receive FaceTime audio calls
Adds call waiting support for FaceTime audio and video calls
Adds the ability to block incoming iMessages from individual senders
Includes general improvements to the stability and compatibility of Mail
Improves the accuracy of unread counts in Mail
Resolves an issue that prevented Mail from receiving new messages from certain providers
Improves AutoFill compatibility in Safari
Fixes an issue that may cause audio distortion on certain Macs
Improves reliability when connecting to a file server using SMB2
Fixes an issue that may cause VPN connections to disconnect
Improves VoiceOver navigation in Mail and Finder
Improves VoiceOver reliability when navigating websites
Improves compatibility with Gmail Archive mailboxes
Includes improvements to Gmail labels
Improves Safari browsing and Software Update installation when using an authenticated web proxy
Fixes an issue that could cause the Mac App Store to offer updates for apps that are already up to date
Improves the reliability of diskless NetBoot service in OS X Server
Fixes braille driver support for specific HandyTech displays
Resolves an issue when using Safe Boot with some systems
Improves ExpressCard compatibility for some MacBook Pro 2010 models
Resolves an issue which prevented printing to printers shared by Windows XP
Resolves an issue with Keychain that could cause repeated prompts to unlock the Local Items keychain
Fixes an issue that could prevent certain preference panes from opening in System Preferences
Fixes an issue that may prevent migration from completing while in Setup Assistant
Security Fix
But this is not what this update is really about.
It was discovered last week, with the release of iOS 7.0.6 and 6.1.6, that iOS and OS X both are plagued with a very critical SSL flaw that allows sniffers to intercept incoming and outgoing connections from an iOS or OS X device, provided that they’re on the same network.
Thankfully, Apple has finally patched the flaw with the release of OS X 10.9.2, and I can’t emphasize enough how important this update is.
Therefore, it is highly recommended that you go ahead and update your Mac right away to patch your computer from this major vulnerability.
What's New
Version 10.9.2:
Security Fix
25-02-2014 8:30 PM
Updated
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
- « Previous
- Next »
