Adding device to Google+ [Solved]
Mav
Fixes: 516
Not sure whether this should be in the Windows Software forum.
Because my S4 Mini is being sent for repair I am using my HTC Sensation. This had been reset to factory defaults around 18 months ago.
I have set up wireless and Google+ using the correct username and password without problem but when I log into Google+ on the PC to access Play Store to select and download apps to the Sensation (I find it easier this way) the Sensation does not appear in the drop down list of devices. The last device I added (Acer tablet) appeared almost instantly.
Can anyone offer some advice on this, please?
Edit: It is now showing - some 90 minutes after adding the Google+ account on the phone.
Forum Moderator and Customer
