Where has the plusnet bandwith test gone
BLUECRUISER2
Could some one please tell me what has happened to the plusnet bandwidth test as really like it, and hope it will be back soon as the bt is not so good for me as like to keep records over a month
jim:red All caps removed from title and post as per forum rules mod:end
42 REPLIES 42
Oldjim
Resting Legend
Fixes: 63
Re: WHERE HAS THE PLUSNET BANDWITH TEST GONE
hulls
Re: Where has the plusnet bandwith test gone
I used it this afternoon and it was in the usual place.  Smiley
pierre_pierre
and I have just got it with three different routes  Roll_eyes Wink
mikko
I can't use My Broadband Speed as it sometimes give impossibly high results. E.g. I just got a download speed of 28661 kbps but I sync at 9500 kbps (See attachment, taken today at 19:38).
Speedtest.net used to do the same but has now been updated to give realistic results (it now ignores the sudden blips that  My Broadband Speed records as actual download speeds).
Thinkbroadband always gives very consistent results and is the best in my opinion.
BT speedtester not for those on LLU.
matt_2k34
Mikko, thats normally caused by security software, might be worth poking round the forums to see several solutions dependant on what package you have Smiley
(the speed "blip" Smiley )
Gus
seems the site just went terminal
The remote device or resource won't accept the connection Detected
The device or resource (www.mybroadbandspeed.co.uk) is not set up to accept connections on port "The World Wide Web service (HTTP)".
edit: didn't see the service status till now
We are currently aware of problems accessing the broadband speed tester
we host at www.mybroadbandspeed.co.uk
Attempts to access the site are intermittently timing out or being
refused.
FTTP 500 regrade from Tues 28th November
Still no access at this time.
matt_2k34
Theres not been a closed service status!
PlusComUk - I'd recommend you get service status emails, or monitor the status traffic lights Smiley
Adie:quote
Thanks.
klyne
Re: Speed faults - information needed to help diagnosis
Is there a problem with the speed tester on the Plusnet website as I have not been able to use it since yesterday morning?
David
Oldjim
Resting Legend
Fixes: 63
split off and merged with existing topic
Oldjim
Resting Legend
Fixes: 63
Quote from: Bob
Yes it is, and if I'm honest it's likely to be down for a while because we're going to need to go down to London and bring the boxes back to Sheffield for some TLC.
chandu
Still unable to access it.
Chandu.
matt_2k34
Of course you cant.
Without trying to sound like a broken record...
Quote from: Matt_2k34
Quote from: Bob
Service: Portal
Posted: Tue, Jul 26 2011 at 17:41:48
Subject: Access to www.mybroadbandspeed.co.uk (67839) - UPDATE
This is an update to this afternoon's post about the problems accessing the broadband speed tester we host at www.mybroadbandspeed.co.uk.
We are arranging collection of the affected servers from one of our London data centres so that the necessary remedial work can be carried about before access to the service can be restored.
Access to the speed tester will remain disabled until we've had the opportunity to carry out this work.
Please accept our apologies for the continued inconvenience.
Kind regards,
Customer Support
Check the Service Status
It will have "Subject: Access to www.mybroadbandspeed.co.uk (67839) - RESOLVED" when the necessary work has been completed, and the service is back online.
Regards
