Ticket 43313683 - Re LTB - Slow responses by support
- Feedback
- Plusnet Feedback
- Ticket 43313683 - Re LTB - Slow responses by suppo...
Re: Ticket 43313683 - Re LTB - Slow responses by support
22-07-2011 8:48 AM
I note that Andrews & Arnold say "We'll even give you visibility of the dialogue we have with BT on the fault tickets we raise (via our control pages) so you can see what is going on."
http://www.andrews-arnold.co.uk/broadband-trial.html
Are plusnet able to provide such details so it is possible to see exactly what is being done to fix this ongoing problem?
It is becoming increasingly difficult to understand why we are still no further forward on this matter several weeks down the line. There doesn't even appear to be any light at the end of the tunnell.
It is time a line was drawn under this. If I can see what is being done to resolve this it would be a help.
22-07-2011 10:33 AM
Sadly this does not appear to be the case. I simply do not accept that it can take this long to sort out my problems. This ticket was opened on 06/06/11!
Long before now this problem should have been escalated to a senior Manager Both at plusnet & BT. Instead you just expect me to sit back & wait for 'somebody' to decide to do something.
The way I see it that 'somebody' may decide to get off their ass when thay can be bothered. Be it today, next week next month or next year.
For two companies in the communications business it is farcical that Plusnet and BT can treat customers in such a totally unaceptable unprofessional way.
22-07-2011 10:58 AM
Quote I simply do not accept that it can take this long to sort out my problem
To put it simply we became aware at the end of last week that our suppliers were having issues fulfilling our requests to correct speed profile inconsistencies. This is still an issue and has been escalated to account manager level with them. We're waiting on this issue being fixed before your speeds can return to normal, it's as simple as that I'm afraid.
We'd like you to know that we are doing all we can to expedite this from our side of things and will keep you updated as to the progress of this matter.
22-07-2011 11:08 AM
Quote from: Matt I've just run a line check which showed up a consistency fail, so automated reprofiling is now going ahead which should fix this (the consistency check fail is the reason your profile hasn't been updating). I'll check the line shortly and let you know how that's gone.
The first you should have been aware of potential consistency fail problems with me was when this process didn't work on 08/07/11. That is two weeks ago today. So I really am not sure why you only decided there was a problem a week later 'at the end of last week'.
The alarm bells should have been ringing long before the end of last week. On my line alone four attempts were made to correct the consistency fail!
It really does seem that little effort is being made by Plusnet Faults & BT 'Managers' to fix this. It is very easy for someone to say we are doing all we can to fix this. But where is the evidence that is actually the case?
22-07-2011 11:24 AM
Quote The first you should have been aware of potential consistency fail problems with me was when this process didn't work on 08/07/11. That is two weeks ago today. So I really am not sure why you only decided there was a problem a week later 'at the end of last week'.
We did suspect an issue but again we're reliant on our suppliers being aware of this and dealing with this for us, which they are now.
Quote It really does seem that little effort is being made by Plusnet Faults & BT 'Managers' to fix this. It is very easy for someone to say we are doing all we can to fix this. But where is the evidence that is actually the case?
As mentioned every effort is being made to expedite this issue being resolved.
22-07-2011 12:17 PM
22-07-2011 12:25 PM
22-07-2011 12:29 PM
22-07-2011 12:58 PM
25-07-2011 8:53 AM
25-07-2011 9:20 AM
25-07-2011 9:48 AM
I know your hands are tied as you rely on updates from the Plusnets Faults Manager and Your BT Accounts Manager.
Clearly they are both very poor at communication. And very slow at fixing problems!
25-07-2011 10:36 AM
Quote I know your hands are tied as you rely on updates from the Plusnets Faults Manager and Your BT Accounts Manager.
I wouldn't say that my hands are tied, I'm communicating regularly with our faults manager who is being extremely co-operative and communicative and so are BT who are working hard to fix the issue.
25-07-2011 11:09 AM
In that case it is surprising that between them they have still been unable to find a solution to fix this problem.
I would have thought by now they should have decided on a way forward!
25-07-2011 11:17 AM
- Feedback
- Plusnet Feedback
