Ticket 43313683 - Re LTB - Slow responses by support
cornwallsurfer
Can somebody at plusnet please look at this ticket. I have now taken two days off work and am no further forward. I feel a MAC code request will be the next step.  Sad
140 REPLIES 140
adamwalker
Fixes: 221
Re: Ticket 43313683 - Re LTB - Slow responses by support
I've got your account open in front of me now cornwallsurfer. I'll come back to you with more info shortly.
I hope we can turn this around soon for you.
Adam.
 Adam Walker
cornwallsurfer
Hi Adam. Thank you very much for such a quick response both on here and by telephone. I look forward to seeing how the SNR reset goes.
I will keep a close eye on the sync rates over the next 10 days.
adamwalker
Fixes: 221
Thanks a lot, as mentioned I won't just rely on the SNR reset, I'll check back with you every few days for signs of improvement and we'll get an engineer out to you ASAP if nothing changes.
 Adam Walker
cornwallsurfer
Hi Adam
I have left some stats on the ticket for you to have a look at.
Kind regards
cornwallsurfer
adamwalker
Fixes: 221
Thanks,
It looks like things are getting better and that the connection is remaining stable. I've set my self a reminder to check back with you next week.
Don't worry about posting router stats as we can gain that kind of info from line tests.
 Adam Walker
cornwallsurfer
Whats happening. No profile change?
adamwalker
Fixes: 221
As mentioned on the ticket the profile change depended on the connection remaining stable for 48 hours. Unfortunately that hasn't happened.
I'm picking this up with our faults team now who should respond again ASAP.
 Adam Walker
cornwallsurfer
Thanks Adam. I noticed the router had reset itself but not sure how many times it has done this.
cornwallsurfer
Hi Adam
The latest change seems to have done the trick.  Grin
adamwalker
Fixes: 221
Good news, thanks for letting me know Smiley
 Adam Walker
cornwallsurfer
My plusnet profile is correctly showing 8Mbps. However the BRAS seems to be stuck on 6Mbps. Cry
adamwalker
Fixes: 221
Your profile both with us and on the BRAS is currently 8mb. Can you try running a test at http://www.speedtester.bt.com
 Adam Walker
cornwallsurfer
Hi Adam
Tried the bt speed test last night & this morning and BRAS was showing 6Mgps. Will try again later after work.
Thanks for your quick response.
adamwalker
Fixes: 221
No probs, I'll look out for a reply.
 Adam Walker
