Connecting to wifi
deanlaura14
Connecting to wifi
I am having problems connecting my laptop to my new plusnet router.
Everything else is connected, phone, TV etc all fine.
My laptop however fails to find it. I have played about with the hub manager and my laptop settings to no avail. It does find a hidden WiFi which is strong and tried to connect by putting in the WiFi password and name but no joy.
Tags (2)
13 REPLIES 13
Strat
Fixes: 565
Re: Connecting to wifi
Moderators Note
This topic has been moved from Broadband to My Router.
Fixes: 420
@deanlaura14  Welcome to the forum.
When you say that your laptop can’t ‘see’ the new hub SSID, do you mean that when you go to the laptop available wireless networks that the hub SSID is not displayed, or that you can’t connect to it?
What operating system is your laptop using?
Gel
Aspiring Champion
Fixes: 29
Legend
Fixes: 260
@Gel I suspect this is a Hub2, on which you  cannot split the  bands.
deanlaura14
It is the hub 2. There is 2 bands though, 2 and 5, don't need both on?
deanlaura14
My laptop is windows 10 and it doesn't detect any plusnet wifi
Legend
Fixes: 260
@deanlaura14 There is a way to disable the 5gHz band, but if your equipment is modern enough to support the 5gHz band, it will operate better on that one - and being a W10 machine, I suspect it will be compatible. Can you post a screen shot of the networks it has found, please?
Fixes: 420
@deanlaura14
On the back of the hub you will see a small hole labelled factory reset. Push a paperclip or similar in the hole and you will feel the reset switch operate. Hold the switch closed for at least 20 seconds. This will reset the hub. Leave it to reset itself and connect to the network again. Then see if that cures your problem.
deanlaura14
I tried that, no luck
Legend
Fixes: 260
Can you do as I suggested in post #7, please?
Fixes: 415
@deanlaura14  if none of the above suggestions work then it MIGHT be worth trying changing the wireless mode to 2 from the default of 1 to see if that helps
See here for details https://www.bt.com/help/broadband/what-is-the-wireless-mode-feature-on-my-bt-smart-hub- ( yes I know that link is for a BT smart hub but the PN Hub 2 is basically the same )
deanlaura14
I turned the 2 on aswell as 5. Would this slow anything down? And how come there is two? Sorry I'm new to Internet
Legend
Fixes: 260
@deanlaura14 Having both bands on - if that is what you mean by 'I turned the 2 on aswell as 5' , this will not slow anything down. The reason for having two bands is that the 'old' 2.4gHz band is becoming a little congested, and the 5gHz band was introduced to ease that congestion, although some devices - especially older ones - do not support it.
