Changing my wifi password
rachelm
Is it possible to change my wifi password and how do I do that?  I searched on the website but I think the page I came to was just for changing my password for the plusnet site.
3 REPLIES 3
Fixes: 416
Re: Changing my wifi password
@rachelm  you should find the information you need here https://www.plus.net/help/broadband/router-user-guides/
Select which router you have and then click on the 'How do I change my Wi-Fi settings'
Hope that helps
Fixes: 1,485
Moderators Note
This topic has been moved from ADSL Broadband to My Router
OskarPapa
Fixes: 65
Hi @rachelm, thanks for your post.
With regards changing the WiFi password, we'd definitely advise following the link that @MisterW has provided.
When you land on the page, click 'I have a 2704n router' followed by 'How do I change my WiFi Settings'. The steps will tell you exactly how to get it done.
Please let us know if you need any further assistance.
