You can't change your products for the moment, you have an order which is currently being processed.
stewartra
I'm getting the above message when I log into my account (and have been for some time). I want to renew but it's not allowing me, can you fix this known issue.
Thanks.
3 REPLIES 3
adamwalker
Fixes: 221
Re: You can't change your products for the moment, you have an order which is currently being pro...
Hi there, sorry for the issue that's preventing changes being made to your account, I've just fixed that for you so you should be able to login and do anything you need to now. Please give me a shout if there's any further issues though.
 Adam Walker
Graculus51
Re: You can't change your products for the moment, you have an order which is currently being proces
I have had exactly the same problem since I joined Plusnet some weeks ago, and presumed this was a normal message on joining ?
Only tonight have I realised that this is a known problem, so can someone please fix me as well.
Thanks yery much.
SammyM
Fixes: 98
Thanks for getting in touch @Graculus51, I am sorry for the issue you are seeing and for the hassle it is causing.
I have requested this to be corrected by the relevant team and once it has been sorted, I will come back to you here
 Sammy M - Sheffield Team
