Number port Customer Letter of Authority
klemm
I need to complete this Customer Letter of Authority (CLoA) to port my number from plusnet to twilio.  What address and email address should I use for plusnet?
https://assets.cdn.prod.twilio.com/documents/UK_LOA.pdf
10 REPLIES 10
Fixes: 420
Re: Number port Customer Letter of Authority
@klemm
I see that you are posting on the Home Phone Forum.
Presumably you are aware that if you port your number away from Plusnet that your broadband service will automatically cease and your account closed, possibly triggering Early Temination Charges?
Moderators Note
This topic has been moved from Home Phone to My Account/Billing
klemm
@Baldrick1
Yes, fully aware.  I new have new separate FTTP line/service from another provider and been out-of-contract for many years paying massively over the odds.
Fixes: 409
Plusnet's address is:-
Plusnet PLC
The Balance
2 Pinfold Street
Sheffield
S1 2GU
That's what I used on a LoA , but there was no requirement for an email address and AFAIK there isn't one
klemm
I finally got around to doing this but new provider need some more information about my phone number carrier (apparently Plusnet PLC is just the retailer not a carrier).  I assume this is BT, my line and number has always been BT before plusnet.
I found a list but my number could be with 001 or 293 according to https://www.telecom-tariffs.co.uk/codelook.htm.
"If you are billed by a reseller, we also need to know the actual communication provider. Please, reach out to your reseller to get the losing provider information. Seems the losing carrier listed on the LOA -Plusnet Plc, is a Reseller and not an actual Losing Network communication provider (LCP). For porting we need to know who is the actual losing carrier provider(LCP) of the number. Could I please ask you to check with the end-user to reach out to Plusnet Plc in order to find out from where they are taking services for the number? So we can place the order to the correct LCP."
001 BT 01/1994
293 BT 06/2006
288 BT Global Services Ltd 05/2006
614 BT Lancashire Services Limited 10/2011
377 BT OnePhone Limited 11/2013
283 BT Wholesale 04/2006
Fixes: 409
LCP is 'losing communication provider' and it is Plusnet Plc!
What you're being told is rubbish
BT is likely the Range holder (RH) but the port request must go to the LCP  since they are the current 'owner' of the active line.
klemm
😩 this is much harder than it should be.
I've told them the Network Provider is BT and reaffirmed the Retailer/CP is Plusnet (LCP).
Lots of confusing info even from the gaining provider https://support.twilio.com/hc/en-us/articles/226194807-United-Kingdom-Porting#:~:text=the%20port%20o...
Fixes: 409
May I ask , why twilio ? Aren't they US  based
I'd try porting to a UK supplier who actually understands the process
klemm
HQ is US but they have global infrastructure.
Main advantage to me is cost and flexibility.  Port costs $5, then monthly fee for number hosting is £0.94.  Everything else is usage based, I rarely use the number but didn't want to loose ownership of it when I cease my copper line.
Twilio is not really a consumer based VOIP but I have commercial and software development experience on their platform.
Fixes: 409
OK, fair enough.
I'll try and find a copy of my port forms when I ported to Sipgate and pm a copy to you for information
Fixes: 409
@klemm  ok , I've checked back at my porting and LoA forms, most of the information is personal e.g name, address, phone number etc so I can't really post or pm it.
However on the LoA ,  Current Service provider is specified as :-  Plusnet PLC, The Balance, 2 Pinfold St, Sheffield, S1 2GU
Again on the Port form , Current provider is specified as :- Plusnet PLC, The Balance, 2 Pinfold St, Sheffield, S1 2GU
There's one other bit of info on my port form that's not personal , an account no which I assume I got from a Plusnet bill
