MAC code from BT - dragging heels
pb123
I have just signed up to Plusnet.  I can not progress my order without a MAC code from BT. Even though my account with them is completely up to date, they are quoting 7 - 10 days by email in order to obtain this MAC code to migrate from BT(BT wholesale) To Plusnet(BT wholesale)....  How do I or can I expedite this?
15 REPLIES 15
Oldjim
Resting Legend
Fixes: 63
Re: MAC code from BT - dragging heels
Moved here as it is more appropriate
OFCOM rules are that it has to be provided in 5 working days
Fixes: 410
According to Ofcom regulations http://ask.ofcom.org.uk/help/internet-service/MAC , a MAC code MUST be issued with 5 working days.
If they're not meeting that then tell them you will contact Ofcom.
Edit: sorry if I repeated what you said Jim, it advised me there was a new post but didn't show me it!! so I posted anyway. Smiley
Razorback
Phone them ( 0800 800 150.works). Once you are through to the right dept ask for your Mac Code, refuse to answer any questions, just keep asking for your Mac code With me I had to repeat it 3 or 4 times. They can issue the MAC code over the phone you dont have to wait for them to email. Make sure it is in correct format similar to AAAANNNNNNNN/AANNA.
slavo71
Quote from: pb123
I asked BT for my MAC on the 23/8/14 and they said it would take 5 days via email. Five days came and went so I called them, they said that it had been sent!!! I told them that it hadn't so they gave it me over the phone there and then.
AFTER I had used it to sign up with Plusnet they sent it me via email....twice!
Use this number to call them, it's a UK based call centre so you will get it straight away: 01324 452504 (It's there special offers line predominantly, but they'll sort you out). This shows you the area code so you will not get stung for a peak rate number http://www.area-codes.org.uk/01324.php
Razorback
Also if they refuse to give the MAC code over the phone, hang up and ring back a few minutes later. You should get someone else who will oblige.
pb123
STAVO71 - you have made my day - i called that number and got the MAC code over the phone within 5 minutes - amazing!!  Thank you to all
slavo71
You're welcome, I'm glad my first post was a helpful one  Wink
No T in my name though  Grin
pb123
I spoke too soon.
The MAC code has been rejected by Plusnet saying its expired even though it was only (supposedly) generated yesterday.  I called BT again (01324...) and after much enquiry told me its because "Plusnet have not made an Advice of Transfer to them...." !??  what does this mean - cant get through to Plusnet customer services but thats another story...
MattyC
Fixes: 46
Hi pb123,
Are you ok to PM the MAC key to me? The specification of it should be:
4 letters, 8 numbers, a forward slash, 2 letters, 2 numbers, 1 letter. For example: LLLL12345678/LL90L.
If it's fine or just needs a minor tweak then I may be able to place your order straight away.
Matty
pb123
thanks Matt - have messaged this to you
MattyC
Fixes: 46
Turns out it is an invalid MAC key.
Really sorry to be the bearer of bad news pb123. Chances are you will need to run it past BT again.
Fixes: 410
Sounds like BT are giving you the run around. I would guess that the 'Advice of Transfer' is what gets sent to them (by Btw?) when PlusNet use the MAC. However if the MAC is invalid/expired then they can't use it. MAC codes will expire if not used for 30 days I believe.
pb123
back to BT  "sorry there's nothing we can do - you will get it in 5 days...."  I am driven to despair with these people.
pb123
pressure and stropiness works - all sorted - thank you everyone today
