Sim card
JohnH2
Sim card
I have just obtained an Apple iPhone 15 Plus. How do I get the small Sim card that fits in the phone?
2 REPLIES 2
Legend
Fixes: 260
Re: Sim card
@JohnH2 The card you were initially sent is a '3-in-1' - you should be able to snap the nano-card from the centre,
Fixes: 416
Re: Sim card
The Sim card you have should be a 'triple sim' ( see a typical picture here https://www.1pmobile.com/SIM ). AFAIK the iPhone 15 uses a nano sim, you should just be able to press out the Nano sim part of your existing sim.
