Updating Passwords For Cyberduck
Cyberduck - Changing Password
The following guide advises how to change your password in Cyberduck.
If you run Cyberduck, it is possible to add passwords to a keychain to negate the need to supply a password each time you login.
After you change your password, the next login attempt you make will fail and you just need to enter the new password when prompted to gain access.
Return to the Changing Passwords guide
0 Comments
