Voicemail (Callminder) 1571 in Call Features still awaiting 'activation'!!
- Home Phone
- Voicemail (Callminder) 1571 in Call Features still...
13-04-2012 3:10 PM
I migrated from Vodafoneathome at the beginning of February this year to Plusnet Extra (Phone & Broadband). When I checked my telephone 'Call Features' I noticed that all of the call features that I have chosen were ok except Voicemail (Callminder) 1571 which was awaiting activation!
As the status shows 'awaiting activation' it is not possible to enable or disable other other call features until this problem is fixed.
Now three months on and it is still showing 'awaiting activation' - although I am still able to use Voicemal (Callminder) 1571 without a problem ! I have made several calls to Tech Support regarding this and have been told that it will be fixed. (As I do not have an Answering machine at home then it is important that I do not lose the 1571 feature).
I spoke with Tech Support again yesterday and once again I was told that this problem will be investigated and I can expect to be contacted when it is resolved.
Has anyone else experienced this problem?
Regards, Norfolkman47
Message 1 of 5
(1,468 Views)
4 REPLIES 4
Re: Voicemail (Callminder) 1571 in Call Features still awaiting 'activation'!!
13-04-2012 4:14 PM
I've just checked your account to make sure you've been correctly advised about this, you definitely have. I can see that we've raised problem 70297 to track this issue. As this now seems to be affecting more customers that we originally anticipated I'll be picking this up again next week to see what we can do to increase the priority and push things more quickly towards a fix.
Adam
Adam
Message 2 of 5
(512 Views)
13-04-2012 4:21 PM
Adam,
As he said
if he needed changes made could you do this for him while waiting for the fix?
As he said
Quote from: Norfolkman47 As the status shows 'awaiting activation' it is not possible to enable or disable other other call features until this problem is fixed.
Message 3 of 5
(512 Views)
13-04-2012 4:33 PM
Fixing phone components is rather tricky but I've done this one for you
Message 4 of 5
(512 Views)
13-04-2012 4:37 PM
Thanks Ben,
Jelv, I had no idea that could be done so I was just giving the most honest and accurate answer I was able to.
I'll still make sure we push forward with a bulk problem fix to make sure anyone else that's been affected also gets their issue fixed.
Message 5 of 5
(512 Views)
- Home Phone
