Update after enginner visit
Terranova667
Fixes: 5
ticket number #81595306
Hi i had an engineer come to sort out a issue I had in the property we are moving to, the  engineer did arrive and sort it out but i have not heard anything back since,  the most important part is whether i would need to pay for the work done the engineer seemed to think not but i would like this confirmed
also this was added to my ticket even though the engineer had been "We would like to inform you that your Help Assistant Question [ 81595306 ] has now been returned to the BOT - Phone Faults - Logged Appointments pool. A member of our Support Team will investigate your issue as soon as possible"
can some one from support check what is going on. thanks.
9 REPLIES 9
HPsauce
Re: Update after enginner visit
From your posts on the Be forums it sounds like it had an old-style master socket which was upgraded to an NTE5A, something that BTOR do for free.  Wink
Terranova667
Fixes: 5
I'm hoping that's what is put in the engineer report so then as you say I wouldn't have to pay.
Terranova667
Fixes: 5
received an update Engineer put NTE replaced and the line has been tested and is clear, so Plusnet consider the fault closed,  but still no indication as to whether i will have to pay, there was no mention of it in the updaqte i got so i'm guessing not but confirmation from support would be nice.
MrT
If it's any comfort, I had a NTE5A fitted some months ago when BTOR came to resolve a line fault. I have not had to pay a penny for that.  Smiley
Terranova667
Fixes: 5
that's good to hear, i don't see any charge in the members Centre yet so maybe it will be free, thanks for the reply.
jim:quote
Jaggies
If the engineer was going to raise charges, he should have told you on the visit - if he didn't mention it, it's very likely that the repair was not chargeable.
Terranova667
Fixes: 5
Hi Brian i asked  the engineer if i would ged and was told it's nothing to do with them it's up to my landline provider ie Plusnet, Whether that is true i dunno.
jim:quote
Pettitto
Fixes: 5
There is no charge for this visit Smiley
Terranova667
Fixes: 5
thanks for the reply Chris great to have that confirmed  Smiley
