Phone noises
- Home Phone
- Phone noises
Phone noises
01-05-2013 1:18 PM
Hi I'm new to this forum but been a PN customer since last October.
My phone has begun to make an unusual noise when I dial out. I have had the same phone for about 3 years, a Philips cordless with a base station and 2 handsets. Position, etc of phone & base station has not changed and the dial tone is clear when button pressed, no noise at all. Dial-out noise sounds like that made by the old-style GPO phones, a "ratcheting" connection noise as it finds each digit. Connection is fine, reception is fine, no problems with any conversations. Just this annoying click-click-clicking noise. Any ideas anyone?
Message 1 of 4
(1,302 Views)
3 REPLIES 3
Re: Phone noises
01-05-2013 1:21 PM
Sounds like a switch has been moved from Tone Dial to Pulse dial on either the handset or base station (if it has one).
It may be a physical switch or a software setting on the phone.
Message 2 of 4
(549 Views)
Re: Phone noises
01-05-2013 1:22 PM
Try dialling a friend then pressing a couple of buttons.
If your friend hears clicks instead of tones then this would confirm the above.
What model Philips phone are they ?
Message 3 of 4
(549 Views)
Re: Phone noises
06-05-2013 5:13 PM
http://www.p4c.philips.com/files/c/cd2351s_79/cd2351s_79_dfu_eng.pdf
Page 24 > Dial Tone......Does this help?
Press MENU
2. Select
ADVANCED SET
and press
OK
3. Select
DIAL MODE
and press
OK
The current setting is displayed.
4. Select
TONE
or
PULSE
and press
OK
to confirm.
Press MENU
2. Select
ADVANCED SET
and press
OK
3. Select
DIAL MODE
and press
OK
4. Select
TONE
or
PULSE
and press
OK
to confirm.
Message 4 of 4
(549 Views)
