No Phone since saturday
- Home Phone
- No Phone since saturday
16-12-2013 9:00 PM
Hi
I have logged a call , but my phone line is down and has been since Sat Night...
No dial tone....and broadband speed is down from 7 meg to 0.7 Meg...
I can only phone on my mobile which tells me there is a 30 minute wait...
I have elderly Parents in law , who may need to get in touch with me
I have had no text or message since I reported it yesterday...
Help ?
beaky32
Help ?
beaky32
Message 1 of 5
(1,049 Views)
4 REPLIES 4
Re: No Phone since saturday
17-12-2013 10:36 AM
Hi Beaky32,
It can take 72 hours to get the problem to BTOR. The call centre(s) are unfortunately over loaded due I suspect to the high level of BTOR faults and failure to attend issues which abound here on the forums.
You might get some traction on this issue by going through the broadband fault checker at faults.plus.net - as that is automated for braodband faults, where as pure phone line faults can only be reported via the call centre or a ticket. If it detectes a phone line fault, I'm given to understand that it automatically raises a fault report to BTOR. Note you do not need to run the fault checker on the phone line which has the fault. You can run the fault checker from anywhere, just ensure that you have the number of the faulty line to check what the automated tester reports.
HTH.
PS: You could get your PILs to phone your mobile and hang up so that you can call them back. That does not cost them anything and allows communication to contine, indeed it would enable them to contact you in an emergency wherever you are, home phone working or not.
HTH.
Message 2 of 5
(578 Views)
17-12-2013 4:35 PM
Message 3 of 5
(578 Views)
17-12-2013 5:20 PM
This is the first problem I have ever had with Plusnet....excellent service otherwise...
Will wait until Saturday to see what happens...
Been brilliant up til now , so I can wait a few days if necessary...
Thanks for the replies..
Beaks
Beaks
Message 4 of 5
(578 Views)
19-12-2013 5:37 PM
Well BTOW came today and fixed whatever was wrong, left a note through the door...
2 Days early...
Thanks Plusnet and BTOW...Very pleased with the service....
Regards
Beaky
2 Days early...
Regards
Beaky
Message 5 of 5
(578 Views)
