Strict NAT TYPE on Xbox One.
- Gaming
- Strict NAT TYPE on Xbox One.
11-09-2014 11:39 AM
Having problems when playing online with my xbox one,
I've tried guides that I've found on here to attempt to turn it to a OPEN NAT but no luck.
Is there anyone one that can help assist me?
3 REPLIES 3
Re: Strict NAT TYPE on Xbox One.
11-09-2014 1:48 PM
if you are using technicolor router you need to telnet into router and cone every udp port xbox one uses,reason for that is technicolor routers dont use full cone nat.ask 1 of the plusnet staff to do it if you dont know how.
12-09-2014 1:19 PM
follow this if you are using the plusnet router:
http://community.plus.net/library/gaming/increasing-gaming-compatability-with-the-thomson-tg585v8-xb...
16-09-2014 12:12 AM
I've given up trying to deal with NAT issues between XBOX One and the technicolor router. Put the XBOX on DMZ and works perfectly now!
