Latency/Packet loss while gaming.
Stax
I switched from Sky to Plusnet a few months ago and for the first month everything seemed fine but over the past month or two I've noticed what I believe to be is packet loss. Every so of often there will be a delay with movement or an action whilst gaming.
I've tried everything on my end and I'm always on ethernet so it's not down to wi-fi. I've disabled wi-fi and tested. I've tried multiple ethernet cables of different lengths. I've tried restarting the router. I've tried multiple computers. I've tried disconnecting everything else connected to the network. I've tried DMZ. I'm on a static IP.
My speeds are fine but it's the random spikes I keep having. What else can I try?
6. Data rate: 20000 / 71568
7. Maximum data rate: 25087 / 70999
8. Noise margin: 9.2 / 5.4
9. Line attenuation: 19.2 / 16.1
10. Signal attenuation: 19.0 / 16.1
WinMTR WITHOUT VPN
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| PNHUB1 - 2 | 355 | 350 | 0 | 11 | 615 | 2 |
|410.xe-2-2-0.central10.psb-bng01.plus.net - 2 | 355 | 350 | 11 | 22 | 617 | 17 |
| 411.be5.psb-ir01.plus.net - 2 | 355 | 350 | 11 | 22 | 612 | 12 |
| core1-BE1.southbank.ukcore.bt.net - 2 | 355 | 350 | 11 | 22 | 616 | 12 |
| peer2-et3-0-2.slough.ukcore.bt.net - 2 | 355 | 350 | 12 | 23 | 615 | 17 |
| No response from host - 100 | 75 | 0 | 0 | 0 | 0 | 0 |
| ae1-br01-eqld5.blizzardonline.net - 2 | 355 | 350 | 12 | 46 | 1223 | 13 |
| be2-pe01-eqpa4.blizzardonline.net - 2 | 355 | 350 | 19 | 30 | 618 | 22 |
| 185.60.114.159 - 2 | 355 | 350 | 19 | 30 | 618 | 20 |
|________________________________________________|______|______|______|______|______|______|
WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
WINMTR WITH VPN
| WinMTR statistics |
| 10.8.0.1 - 2 | 347 | 343 | 16 | 22 | 654 | 17 |
| ams-eq6-cr1-v11.31173.se - 1 | 351 | 348 | 17 | 30 | 656 | 17 |
| 80.249.208.83 - 1 | 351 | 348 | 17 | 23 | 659 | 18 |
| ae1-br02-eqam1.blizzardonline.net - 2 | 347 | 343 | 17 | 30 | 656 | 19 |
| et-0-0-3-br02-eqpa4.blizzardonline.net - 2 | 343 | 339 | 26 | 35 | 732 | 27 |
| be2-pe02-eqpa4.blizzardonline.net - 2 | 347 | 343 | 26 | 32 | 665 | 27 |
| 185.60.114.159 - 2 | 347 | 343 | 26 | 32 | 665 | 27 |
My Broadband Ping - PlusNet
I've attached 4 ThinkBroadband speed tests.
1 REPLY 1
Mav
Fixes: 516
Re: Latency/Packet loss while gaming.
Moderator's note:
Thread locked in favour of https://community.plus.net/t5/Fibre-Broadband/Packet-Loss-Latency-whilst-gaming/m-p/1557572#M79628
Forum Moderator and Customer
