Is minecraft prioritized correctly?
StephenF
I'm currently hosting a server for me, a few friends and family and i am hoping to rule out server issues i'm experiencing.
thanks
-steve
5 REPLIES 5
Peter_Vaughan
Re: Is minecraft prioritized correctly?
StephenF
oh thanks i look forward to spending ages learning how to use a program rather than just been given a straight yes or no answer  Tongue
Strat
Fixes: 565
Have you raised a ticket as suggested here http://community.plus.net/forum/index.php/topic,444.0.html
bobpullen
Fixes: 316
No need.
It should be working fine as per my comments in the thread here.
If you've any reason to doubt that then a Wireshark capture would be the way to go though.
jelv
Fixes: 10
That fix presumably relates to people playing minecraft on a server elsewhere. Will it also apply to someone hosting a server?
I think you are going to have to do the wireshark capture to check the priority on the incoming server requests.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
