Heads up Steam users
Oldjim
Resting Legend
Fixes: 63
Portal is free for download until the 24th May and once registered you keep it for ever.
Just downloading at a magnificent 69 bytes per second (not sure if that is Plusnet or Valve limiting it)
Update - it must have been Valve as it is now coming down at full speed
41 REPLIES 41
MrC
Re: Heads up Steam users
Possibly something to do with http://store.steampowered.com/news/3808/ happening at the same time?
Oldjim
Resting Legend
Fixes: 63
That is the reason they gave on my popup
Fixes: 1,485
Ohhh Mac
Oldjim
Resting Legend
Fixes: 63
Free download is also for PC users
Steve
Seasoned Pro
Ah its a great puzzle game this, I have it on the xbox 360, Mind Bending though.
If life gives you lemons, make lemonade.
MrC
Portal 2 should be out very soon - which might be why Valve are giving Portal away now to ramp up interest in the sequel. If Portal 2 is anywhere near as good as Portal then I'll definitely be getting it.
orbrey
Watch the Zero Punctuation review (NSFW unless you have headphones, and even then it's still a bit iffy - take care).
He likes it.
He can't find anything bad to say about it.
If you know Zero Punctuation at all, you'll realise that's pretty much a unique situation.
zubel
Portal is absolutely awesome.
Once you've finished the game itself, go and investigate both http://portalmaps.wecreatestuff.com/ and http://www.wired.com/gamelife/2008/10/portal-prelude/ - should extend your gameplay by several hours (and possibly short circuit your brain!)
B.
paulpicks21
Cheers for the heads up oldjim , just downloading it now.
MrC
Quote from: adiewoo
Ohhh Mac
And maybe also for Linux users...... http://www.phoronix.com/scan.php?page=article&item=valve_steam_announcement&num=1
Steve
Seasoned Pro
It will be good if steam works on linux, i believe thats why a lot of gamers are stuck with windows at the moment.
MrC
It's going to be interesting. I run Steam under Wine at the moment and a lot of games work surprisingly well. I can foresee a need to run Steam/Wine alongside native Steam to support those games that won't run natively.
scootie
cant even get past registering. keeps telling me i am not human and to re enter the characters. filled the form out 10 times now and am not happy.
will try it in FF and see if i can be classed as a breathing living human
Oldjim
Resting Legend
Fixes: 63
We are a bit picky on Steam as to who is let in  Grin
