Solid orange light - plusnet hub 2
- Full Fibre
- Solid orange light - plusnet hub 2
a month ago
Re: Solid orange light - plusnet hub 2
a month ago
Has this ever worked?
a month ago
@HManktelow Welcome to the forum. If you have full Fibre (FTTP), what are the lights on the ONT showing?
a month ago
a month ago
How many ports on the ONT?
Can you please confirm that the Ethernet cable is in the 4th port on the router?
a month ago
As @Townman asked, has the connection ever worked? I am assuming so, as the installer should have checked?
a month ago
a month ago
a month ago
4 weeks ago
Hi @HManktelow I can see you've called in and there was an outage in your area. It is showing you now have an active connection, is everything working ok on your side?
4 weeks ago
Are you able to share the nature of the outage so that we can profile this characteristic for others please?
Is this user on the low touch or the high touch network?
Was this a RADIUS server issue or something else?
4 weeks ago
4 weeks ago
@Townman This is typical, and why I try not t respond whilst away - there is always some 'unmentioned' information - plus I don't spend all day in front of the laptop. 😉
- Full Fibre
