FTTC and FTTP Isposure performance testing
- Full Fibre
- FTTC and FTTP Isposure performance testing
- « Previous
- 1
- 2
- Next »
Re: FTTC and FTTP Isposure performance testing
14-12-2010 10:30 AM
220.27 Mbs
How may people in the UK get this speed displayed in their system tray?
<a href="http://happydays.plus.com"><img src="http://happydays.plus.com/Isposure--220.jpg" /></a>
Dave can you get a profile to use all that connection speed?
In fact at the moment there seems to be visible blips of speed, both up and down. One block of traffic and one or two blocks idle.
Other test results
<a href="http://www.mybroadbandspeed.co.uk"><img src="http://www.mybroadbandspeed.co.uk/results/66253041.png" /></a>
<a href="http://www.speedtest.net"><img src="http://www.speedtest.net/rank/3560465666.png" /></a>
Other test results
Message 16 of 19
(292 Views)
14-12-2010 10:38 AM
Have you actually checked the online results?
Quote from: khill01 220.27 Mbs
I'd bet they reflect the actual speeds your connection is seeing and not what is displayed in your system tray.
For reference, a few times that pop up box has displayed the heady speeds of 2.51Mb/s for my connection however, when checking the online results, the speeds recorded are more consistent with the everso slightly less impressive 2.30 Mb/s my line actually manages.
Paul
Message 17 of 19
(292 Views)
14-12-2010 2:10 PM
Paul says...
Yes, the other two graphics are my speed tests!
And the first graphic is my system tray at 09:17
The validity of the results may be questioned, but what you see is what I got!
Message 18 of 19
(292 Views)
14-12-2010 4:58 PM
I was referring to the Isposure results.
Quote from: khill01 Yes, the other two graphics are my speed tests!
Your line clearly doesn't support a throughput of 220Mb/s, regardless of what the Isposure sys tray pop up shows.In that case, what you see clearly isn't what you get.
Quote from: khill01 The validity of the results may be questioned, but what you see is what I got!
Whereas the results from the two speedtest sites are representative of what you line could/ can achieve and are rather impressive. That was what I was eluding to with my post and the statement I made within it.
Paul
Message 19 of 19
(292 Views)
- « Previous
- 1
- 2
- Next »
- Full Fibre
