BIG Drop in speed
- Full Fibre
- BIG Drop in speed
BIG Drop in speed
19-06-2012 9:44 AM
Hello,
Not sure why but I've seen a massive drop in speed, from ~68/15 down to ~42/9 (simlar results from BT and Speednet).
When I ran the diagnostics test from BT it reported that I was getting 56/10 against a profile of 61 / 20.
I've reset the modem and the router (Airport Extreem) but no change.
Anyone seen similar issues? Any 'testing' going on?
Thanks, Sean.
Thanks, Sean.
Message 1 of 4
(1,376 Views)
3 REPLIES 3
Re: BIG Drop in speed
19-06-2012 10:03 AM
I can see you've raised a fault so we can have a deeper look into this and see if we can identify any issues. I've run a few tests and can't see anything obvious I'm afraid but our faults team should get back to you ASAP about this.
Message 2 of 4
(557 Views)
19-06-2012 10:40 AM
Thanks for looking into this.
Message 3 of 4
(557 Views)
20-06-2012 5:41 PM
OK something very strange going on. Here is the result using Firefox -
Here is the result using Chrome (IE is the same)
Firefox was reporting the same speed previously so not sure what's gone wrong!
Looks like while there is a drop (~10Mbps) it is not as bad as it looked.
Message 4 of 4
(557 Views)
