Profile and GEA test?
Browni
Aspiring Hero
Fixes: 60
Re: Profile and GEA test?
That would be the proverbial length of string, as long as it reaches both ends.
ejs
Aspiring Hero
Fixes: 25
@Manny7860 wrote:
But why is it not synched like on his tester what's causing the loss. I have the standard set up.
Probably because the tester has a Broadcom modem chip, or performs better as a modem for some other reason besides containing different chips.
Manny7860
@Browni got a meg upload increase by changing router to bt hub 6.
Onwards upwards
Excellent!
Fixes: 1,602
Sorry to hear the engineer still couldn't find a fault @Manny7860
But I'm glad that switching to a different router has resolved things for you.
Please let us know if you have any further issues.
Manny7860
@Gandalf got a email and text to say they are charging me for the engineer visit. Can you sort this please.
Excellent!
Fixes: 1,602
Sorry to hear that @Manny7860
I've looked into this and I've updated you by e-mail. Hope this helps.
Manny7860
Received your email reply.
Thank you @Gandalf for sorting this Smiley
Excellent!
Fixes: 1,602
No problems at all.
Please let us know if you need any further help.
Manny7860
@Gandalf Checked on bt adsl checker noticed my download upload max speed has increased. Upload now showing 12.5 was 8.2 haven't seen any difference in speed was wondering would it need a profile refresh for it to register new speeds.
Pics enclosed.
Excellent!
RealAleMadrid
Aspiring Hero
Fixes: 59
You are looking at speed estimates on the checker, they can vary from time to time but don't mean your speeds are going to change. If you could show your full modem/router stats that would help. Not sure what the HH6 can display, I've never used one. You could try a single resync but don't expect your speeds to increase to the estimated values, it probably won't happen.Smiley
Manny7860
I am using the bt hub 6a. The same one as you I believe?
Excellent!
RealAleMadrid
Aspiring Hero
Fixes: 59
I am afraid you believe wrong, I have never used any ISP supplied router, I need a bit more in the way of facilities and configuration options.
However I think you may be able get stats from the BT hub 6 using the following command ......
Advanced settings > enter password > Technical log
Hope this helps.
Manny7860
Data rate: 6.70 Mbps / 39.97 Mbps
Maximum data rate: 6923 / 41140
Noise margin: 6 dB / 6.3 dB
Line attenuation: 21.4 dB
Signal attenuation:
VPI / VCI: 0/38
Excellent!
Fixes: 1,602
Unfortunately as your sync speeds are within expectations there isn't anything we can do to improve them.
Downstream Speed 40.0 Mbps
Upstream Speed 6.7 Mbps
In addition your line is not banded.
Profile Name 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off
Manny7860
Right I see. No problem. Just thought I'd see an little increase due to the increase on the checker.
Excellent!
